Old 03-12-2019, 12:36 PM   #1
JohnB15632
JohnB15632's Avatar
Default Forming the front upper corner after welding
I am having the right upper corner of my A repair welded this Saturday.
My question is, after it is welded, what is the best material I should use to fill and form this area.
Should I use JB Weld or POR15 Epoxy Putty?
Thanks,
JohnB15632 is offline   Reply With Quote
Old 03-12-2019, 12:41 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Forming the front upper corner after welding
Have you considered lead?
Russ/40 is offline   Reply With Quote
Old 03-12-2019, 01:15 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Thanks,
John, the best is going to be 19 gauge sheetmetal that is proper formed and TIG-welded into position. If you don't do this correctly now, it will haunt you throughout the rest of the restoration phases.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-12-2019, 03:42 PM   #4
duke36
Concur. That corner has to withstand a lot of stress and flexing on the slant windows.
duke36 is offline   Reply With Quote
Old 03-12-2019, 09:15 PM   #5
dbaldwi3
dbaldwi3's Avatar
Agreed!
dbaldwi3 is offline   Reply With Quote
Old 03-12-2019, 09:31 PM   #6
fordcragar
fordcragar's Avatar
It looks like that area has been worked before. I would imagine that what is left of the metal that is there, is thinner than original. Do a good repair on it, like what has been mentioned and it will last a long time. Welding it up and filled like what was done before, and it will look like it does now.
fordcragar is offline   Reply With Quote
Old 03-13-2019, 05:44 AM   #7
canadian
as BRENT stated, properly formed new 19 gauge metal, TIG.. and the least amount of body fillers. it can be done .
canadian is offline   Reply With Quote
Old 03-18-2019, 06:32 PM   #8
RB_Nielsen
RB_Nielsen's Avatar
MIG weld or even oxy-acetelene weld works well
RB_Nielsen is offline   Reply With Quote
Old 03-18-2019, 08:38 PM   #9
Synchro909
Synchro909's Avatar
It looks to me like there is a ton of bog in thee already. I'd start removing it till I was back to decent metal that is close to the right shape, then I'd look at what I need to replace. As others have said, I'd use new metal of the correct thickness properly shaped and welded in.
Fix it right, fix it once.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
