03-12-2019, 09:39 AM | #1 |
car cover
I have to put my 1939 standard coupe outside for a few months and am hoping someone can share their experiences and recommendations for the best all weather car cover I can purchase that is most suitable for the coupe body shape.
Thanks Gavin |
03-12-2019, 09:56 AM | #2 | |
Re: car cover
California Car Covers are high quality with a great selection. |
03-12-2019, 09:57 AM | #3 |
Re: car cover
Agreed!
03-12-2019, 09:58 AM | #4 |
Re: car cover
Gavin
I bought a Noah all weather cover from California car Cover in July 2018 and it has been great. Well worth the money. $257.99 with free shipping. Bruce
Works good Lasts long time |
03-12-2019, 10:33 AM | #5 |
Re: car cover
Even with the car cover the moisture evaporating
upward from the ground will rust away the frame. Moisture barrier is needed. |
03-12-2019, 10:37 AM | #6 |
Re: car cover
03-12-2019, 10:56 AM | #7 |
Re: car cover
Go heavy on the wax. Park on pavement, or put a plastic cover on the ground beneath it. California Car Covers are nice fitting. Moisture will penetrate though. They protect from sun.
V12Bill makes a good point.
Enjoy yer day. Tom Hate can't fix what it started. |
03-12-2019, 11:23 AM | #8 |
Re: car cover
Do not put plastic tarps over the car cover! The car will sweat under the tarp and it will damage the paint. Seen that happen more than once.
03-12-2019, 11:33 AM | #9 |
Re: car cover
I also have a Noah and t s a great cover. I do remove it often to use the California car duster they make also. They offer different covers depending on your storage situation.
03-12-2019, 11:38 AM | #10 |
Re: car cover
Use a moisture barrier underneath even if it is sitting on concrete or other paving as moisture will come up through the paving, especially in late winter or early spring. That's why so many so-called barn finds are rusty from the bottom up even if the floor of the barn was concrete.
03-12-2019, 11:54 AM | #11 |
Re: car cover
Thank you very much everyone, you've given me lots to consider and I'll be sure to protect from the ground up.
03-12-2019, 12:39 PM | #12 |
Re: car cover
I put mine in a portable garage for a month(it used to house my tractor), I put lots of moth balls inside and several of those green square rodent pellets around the car, in a day the pellets were gone, I replenished them every day until I brought the car back to the garage. When you do bring it back inside be sure to pull the rear seat to check for any rodent activity.
03-12-2019, 12:41 PM | #13 |
Re: car cover
Several years ago, when I had more cars than I had storage, I had to put some of them in a damp underground garage. I knew there would be a moisture problem, so I looked into what my alternatives were. I ended up covering each car with a cheap thin car cover, and then rolling them into these large plastic bags. The people I bought them from said they were for car storage, but I found later they were originally meant for outdoor grain storage. It took a little effort (the more help you have the better) to get the cars positioned right, but after I got them where I wanted them, I placed a tray of desiccant under each car, and used my shop vac to suck as much air out of the bag as possible before sealing them up. When I removed the cars from the bags the next spring, everything was perfect; no rust, no mold, nothing. They were like the day I rolled them in.
I did the same thing the next winter. That spring, while the results were still OK, they weren't as good as the first year. It turns out that moving the cars in and out and folding them up to store them over the summer caused some pinholes in the bags, so they wouldn't seal perfectly on the second use. They were only about $90 each as I remember, so they were a good one year solution. If you have to do it subsequent years, I would suggest buying new bags every year; 90 bucks ain't that much. I never tried it, but I would expect the results would be good if you left the car in the bag for several years if it weren't disturbed. Just another alternative. |
03-12-2019, 12:50 PM | #14 | |
Re: car cover
Agree 100%....
03-12-2019, 02:07 PM | #15 |
Re: car cover
If you an find some Fresh Cab, it will keep the rodents out and will not make it smell bad. I found mine at Ace Hardware, probably find it on the internet also. Al
03-12-2019, 03:11 PM | #16 |
Re: car cover
Check “car jacket”. Also sold by California Car Covers I believe. I know someone who uses them and he has no mouse or moisture issue parked on a concrete garage floor...Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
03-12-2019, 06:42 PM | #17 |
Re: car cover
Tip on keeping our furry fiends out our cars without the stink of mothballs. Get oil of peppermint from a health food store like Whole Foods. Squirt some on cotton balls in an open container and put them in the car in several places. Renew the peppermint oil in the cotton balls every month or so. Or you can find a product made by Bonide that does the same thing for more money at Home Depot. Active ingredients, you guessed it, Peppermint oil. The critters hate it, but it smells great.
03-12-2019, 07:55 PM | #18 |
Re: car cover
get walk the plank mouse trap i have caught over 125 mice with one
