Old 03-10-2019, 02:14 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Cleaning corrosion off of NOS radiator core
Okay, It's a chebby core, but it should be the same. I have a NOS 37-39 Chevy radiator core that has been in the original box all these years. I cut the box open and it is "white" with corrosion. It's pretty, but it ain't right. How is the best way to remove the corrosion ? Inquiring minds want to know. Thanks.
Old 03-10-2019, 02:17 PM   #2
Phil Gillespie
Phil Gillespie's Avatar
Default Re: Cleaning corrosion off of NOS radiator core
Rinse it off with a mixture of white vinegar and water. Followed with good water flush, then blow with air. Thats how i would tackle it.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 03-10-2019, 10:18 PM   #3
B-O-B
B-O-B's Avatar
Lawson try spraying with WD 40.
B-O-B is offline   Reply With Quote
Old 03-10-2019, 11:12 PM   #4
expavr
expavr's Avatar
Phil NZ
I agree. I’ve used vinegar along with iodized salt to take chemical buildup off of brass and copper items over the years. Works good and its cheap.
expavr is offline   Reply With Quote
Old 03-11-2019, 12:42 AM   #5
flatheadmurre
flatheadmurre's Avatar
Electrical contact cleaner is designed to remove oxide without hurting base material...
And there are sets with a cleaner/flush/corrosion protection.
Might cost a bit more then going for an acid...but should be safe..
