#1 |
bought a new battery and installed it. key on, pushed the starter button and nothing happens. Before I go feeling around in the dark (inexperience) what are the things I should look for as causing the problem.
#2 |
Put your car in third gear and push or use the crank and see if the engine turns over. If so try the starter once more. If still nothing check the connection to the starter and frame ground. If those are good it is either a dead battery or bad starter.
#3 |
Was the car starting before you got the new battery?
All steel from pedal to wheel |
#4 |
Check the terminals are clean and tight.
When I was a kid I had no money (like most of us) so it was commoon to have a flat battery. To test the condition of it, we would turn on the lights, then either hit the horn and watch what the lights did and listen to the horn or we would turn on the lights and hit the starter, again watching the lights. Running either or both of these tests should tell you about the battery and the connections. If all that checks out OK, I'd look at the starter motor. Is the pinion stuck in the ring gear/ Is it servicable? Is the engine free to turn?
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
#5 |
Hi Bart,
New batterys usually come with plastic protective caps on the terminals, be sure they have been removed, don't feel bad if there still there, seen it happen many times, we wont tell.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
#6 |
#7 |
Well, like I said inexperience. Took the starter rod assembly apart and realized I just was not pushing hard enough. Seat is out while cleaning the rat poo out so was pushing by hand. Foot made it crank.
#8 |
Great news thanks for the update congratulations working on solving problems will help you and you will see one day you will be helping one of us
