Old 01-31-2019, 02:13 PM   #1
31Abone
31Abone's Avatar
Default model B 4" head gasket info needed
got model B bored to 125 thou to 4" what head gasket to use ? the gasket I used leaked water into #3 cyl.
31Abone is offline   Reply With Quote
Old 01-31-2019, 02:25 PM   #2
Charlie Stephens
Default Re: model B 4" head gasket info needed
Long shot but is there any chance someone sold you a Model A head gasket by mistake? If you are not sure of the difference post pictures.
Charlie Stephens
Old 01-31-2019, 02:40 PM   #3
Bob C
Also what head are you using.
Bob
Old 01-31-2019, 02:57 PM   #4
abachman3
abachman3's Avatar
Best Gaskets, graphite are available either as a Model A or a different one for Model B.
abachman3 is offline   Reply With Quote
Old 01-31-2019, 07:10 PM   #5
Jim Brierley
At one time 'big bore' and 'big valve' gaskets were available. Contact Egge Machine to see if they still are. Also you might need to plug the 4 small holes in the B block??? Plug flush with the deck surface to support the gasket.
Jim Brierley is offline   Reply With Quote
Old 01-31-2019, 08:29 PM   #6
31Abone
31Abone's Avatar
B block bored to 4".stock C head all model B engine
Old 01-31-2019, 08:51 PM   #7
Pete
Locate the gasket very accurately on the head and see if the fire ring hangs over anywhere.
Then locate the gasket on the block and check for the same.
If it hangs out, it won't work. The cure is a different head.
If it hangs out on the block, try a different gasket.
I have used the standard copper gasket several times with a 4.030 bore race engines.
