Old 01-31-2019, 10:47 AM   #1
melisahe
melisahe's Avatar
Default how do you remove trunk cyl lock
1938 Ford-How do you remove the trunk cyl lock if you don't have the key>I want to replace with a good one. All info much appreciated. Thanks Mike
melisahe is offline   Reply With Quote
Old 01-31-2019, 03:35 PM   #2
40cpe
40cpe's Avatar
Default Re: how do you remove trunk cyl lock
I'm sure there are different ways, but mine needed the spring replaced on the lock cover, too. I drilled out the spot welds on the cover on the back to gain access. That opens up the whole area to work. You can replace the cover by welding or sheet metal screws as it is hidden when installed.
40cpe is offline   Reply With Quote
Old 01-31-2019, 04:06 PM   #3
milo
milo's Avatar
I have a 38 also and had to carefully drill my old cylinder out to put in a new lock cylinder...
You're born, you die, in between you build hot rods
milo is offline   Reply With Quote
Old 02-03-2019, 05:21 PM   #4
Flathead Fever
Flathead Fever's Avatar
In the Home Depot parking lot the guys that removed my truck lock used a hammer and a screwdriver.
Flathead Fever is offline   Reply With Quote
