01-12-2019, 07:47 PM | #1 |
Ignition Wire
I have a 12V 1929 roadster with a dual point Mallory distributor and an after market ignition switch. I am trying to determine what type of wire to run from the ignition switch to the distributor.
Thanks |
01-12-2019, 08:08 PM | #2 |
Re: Ignition Wire
14-16 ga should be fine
01-12-2019, 08:37 PM | #3 |
Re: Ignition Wire
much thanks
01-13-2019, 12:48 PM | #4 |
Re: Ignition Wire
From the ignition switch to the coil, not to the dist.
01-13-2019, 01:30 PM | #5 |
Re: Ignition Wire
