#1 |
That metal tube that the fuel pump push rod goes into and hangs down from the bottom of the fuel pump stand, is this necessary?
Reason I ask, I have an old NOS military stand that doesn't have one. I'm assuming I can fit another piece of pipe in it, but curious what it does and is it necessary? Would a piece of copper pipe with the correct O.D. work in it's place? |
#2 |
Itīs just there to control oilvapour/ventilation so material of the pipe shouldnīt be a problem as long as it stays in place.
The pressed in steel pipes come loose sometimes so wonder if the copper will be tough enough for a press fit....maybe with some loctite... |
#3 |
Tim, I remember having that tube on my original 40 Ford engine years ago. I think it was a breather tube similar to a a crankcase road draft breather tube to draw fumes out of the engine and have them go down behind the engine instead of into your engine compartment. The copper pipe idea would work. Mine was a type of flex piping.
#4 | |
![]() Quote:
#5 |
#6 |
#7 |
I guess, but I have this one all prepped and ready for paint. Oddly, I didn't realize the tube was missing until I was about to lay the final coat. I was think of trying to remove the one from the old breather unit, but that press fit is tight.
#8 | |
![]() Quote:
The tube in question probably could be left off without any ill effects.
#9 |
#10 | |
![]() Quote:
Nope, your picture correctly identifies what I'm trying to explain. The flex pipe breather to get the fumes to go under the car is something different. Thank you for that. So, they short, approx. 1/2" O.D. X 6" long pipe does not need to be replaced or isn't necessary? |
#11 |
I don't know for certain but I think the tube was added to help keep more of the vapors in the engine while the vehicle is parked but idling and after shut down. The oil filler is the air inlet for the crankcase breather system. The outlet on the front right side of the oil pan is dependent on air movement to keep a draft going that direction.
It won't hurt to leave it off. An engine with a lot of blow by might be better off with it. Mac VP sells the tubes for replacement. |
#12 | |
![]() Quote:
#13 |
Donīt think ford ever spent a $ on things not needed...so thereīs a reason it was installed from start...Muntz engineering...lol
#14 | |
![]() Quote:
#15 |
I have also seen them in different lengths . Friend had one that was long enough that it was just barely making contact with the umbrella on the push rod . Enough that it warped the base and as a result you loose some stroke on the pump. I don't have one in mine. It came off so I removed it and didn't replace it.
#16 |
Opps! Count me as being WRONG about your tube.
#17 |
If you have one, use it. It does serve a purpose. It isn't THAT tight a press fit.
That tube cost something like $.06. If Henry could have deleted it he would have. Mart. |
#18 |
We don’t have any extra of those tubes.....my fuel pump stands have them as they should. I would remove the tube from your old stand and install it in the replacement stand. They are a tight press fit into the pot metal stand. To safely remove the tube, clamp your old stand in a vice. Push a 9/16” deep socket up the tube til it gets to the base. The socket will be very close to the ID of the tube. Now you can get a tight grip around the tube with a pipe wrench.....carefully twist the tube around as you pull on it. The tube should break free of the base. Push out the socket.
Clean it up so that it’s shiny bare metal. Put some locktite on the end and tap it into your replacement stand.
#19 | |
![]() Quote:
