Old 01-06-2019, 02:33 AM   #1
fordlovr
fordlovr's Avatar
Default Rear Hub Seal.
Can the rear hub seal be replaced with just basic tools? Or do you need specific tools to do this? I have a leak coming down the outside of the backing plate which I dont believe is brake fluid. But of course wont know until I pull the Drum off. cheers
fordlovr is offline   Reply With Quote
Old 01-06-2019, 02:37 AM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Rear Hub Seal.
You'll need a good hub puller . If it's gear oil you'll likely need new axle seals located inside the axle housing.
Ken/Alabama is offline   Reply With Quote
Old 01-06-2019, 11:06 AM   #3
drolston
drolston's Avatar
Just hope that the axle seal is bad and not pitting on the axle housing surface. Also check that differential lube is not over full, like all the way level with the fill opening. Should be about a finger width below that.
Old 01-06-2019, 11:12 AM   #4
19Fordy
19Fordy's Avatar
fordlovr: The answer is "YES". Read all this.
https://www.fordbarn.com/forum/showt...son+hub+puller
Do a search for "KR Wilson Hub Puller" if you want more info. This topic has been covered the the "nth degree" so there's lots of information.
