Old 12-17-2018, 11:19 AM   #1
whizzernick
whizzernick's Avatar
Default 1934 fan belt legnth
I just tried to install a fan belt on 34 I am working on . belt was new (33-36 )
belt was too short . I ended up having to change generator pully to smalest could find. belt is on but very tight gen is as low as it can be. Any ideas why ?
I know that a longer belt will work. any one had this before ?????
whizzernick is offline   Reply With Quote
Old 12-17-2018, 05:19 PM   #2
Karl
Karl's Avatar
Default Re: 1934 fan belt legnth
Yep The ones sold by the Parts houses are to short.
There is a Gates belt which fits much better -can't remember the details but
will be on here somewhere (540 seems to resonate) . I would not run with the smaller belt I did and the inlet manifold broke at the generator mount -Pushing the fan and generator through the radiator -Not good. May not be totally due to the tight belt but it wouldn't have helped -Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 12-17-2018, 05:51 PM   #3
petehoovie
petehoovie's Avatar
I found this fan belt from NAPA fits my '34 with no problems.
See it at > https://www.napaonline.com/en/p/NBG5L570
and here > https://www.vbeltguys.com/products/b...classic_v-belt
5L570 NAPA AUTOMOTIVE Classic Replacement V-Belt
Specifications
Belt Length 57" (1448mm) Belt Top Width .66" (17 mm) FHP Belt Nominal Length 57 in. FHP Belt Nominal Top Width .66 in. UNSPSC 26111801
Old 12-17-2018, 06:21 PM   #4
koates
I also had the same fan belt problems some years ago on my original 34. I use a Dayco or Gates or Good Year B54 which is 57"around. You also have to watch the tops of the radiator hoses for fan blade clearance as it is pretty close there. Regards, Kevin.
koates is offline   Reply With Quote
Old 12-17-2018, 07:47 PM   #5
DavidG
DavidG's Avatar
Always a good idea to give the fan a test spin by hand before starting the engine after installing a new fan belt.
Old 12-17-2018, 07:59 PM   #6
whizzernick
thanks :: I do have a fan belt length checker and belt that I have is 56" I think 57 sounds right
thanks again
Old 12-18-2018, 01:30 PM   #7
Karl
Karl's Avatar
Use the correct length belt and hopefully avoid this
Old 12-18-2018, 07:23 PM   #8
DavidG
DavidG's Avatar
Ouch!
Old 12-19-2018, 07:57 PM   #9
Karl
Karl's Avatar
Originally Posted by DavidG View Post
Ouch!
Yes - Happened at the end of a 1200 mile trip about 30 seconds after I commented to my wife how well the car had gone. Was a big bang- followed by lots of steam and water on the road ! The AA (our AAA) told me that they would sent a repairman out first to assess the situation and repair the car if he could . My response was just send a truck! -Karl
Old 12-19-2018, 09:59 PM   #10
whizzernick
I installed napa belt and fit is correct.
THANKS AGAIN
