#1 |
As per my previous threads, keeping my pickup 6 volt positive ground. I just finished making the cables for the battery to solenoid and solenoid to starter. Tightening down the starter end and it is stripped. Ran a die and looks like threads have taken a beating over the years. What is the process to replace the stud and where can I source one ? I am hoping to find something local through a parts store if possible.
Thanks |
#2 |
I think C&G Ford has them.....https://cgfordparts.com// Check them out, even though they are in Cal. Do you have a N A P A ? they might surprise you. Best of luck, m
#3 | |
![]() Quote:
#4 |
Look at auto parts store in the "help" section, there is a repair stud for later Ford starters that can work
#5 |
There is a copper repair adaptor made just for this.
It has a female thread, is about an inch long with a long hex and male threads on the top. There is one on the starter I am working right now and had it off a dozen times. Just make sure you tighten the lock nut on the bottom tight first. G.M.
www.fordcollector.com |
#6 |
You want a solid connection at the starter That's reliable since its a heavy draw. |
#7 |
Found the right part locally at a starter alternator rebuilder. J & N : 452-14014
Description, Stud, Field, Copper, 1.53"/38.9mm L Alternate part numbers; Canadian Auto Part : HDW2520 FORD : 18-11102A PRESTOLITE : 90-876 Thanks for the help |
