Old 10-28-2018, 12:00 PM   #1
lotsagas4u
Default 1933 hood/grill gap help
Need help, advice on my 33 coupe, I have a half inch or so gap between my hood and grill. The center strip is adjusted all the way up with the front and rear brackets. The hood gap is good at the cowl, but short in the grill top area. Seems like the radiator needs more tilt. I also have a small gap where the hood latches are near the fenders, Any thoughts/tricks on this? Thanks
lotsagas4u is offline   Reply With Quote
Old 10-28-2018, 04:47 PM   #2
bill3337
bill3337's Avatar
Default Re: 1933 hood/grill gap help
Can you take a photo of from the top at the grille to hood and one of the side to the grille and one more from the bottom of the hood to the inner fender. Maybe one at the sides of the cowl would help too.
bill3337 is offline   Reply With Quote
Old 10-28-2018, 06:39 PM   #3
DavidG
DavidG's Avatar
There's a reason that '33-'34 grills originally had flat black paint between the raised portion of the grill and the hood lacing on the grill.
Old 05-16-2025, 08:03 AM   #4
s.e.charles
s.e.charles's Avatar
this thread came after a search for '32 grill tilt' and i don't want to start another.
Q: why do some grill shells tilt forward at the top?
i thought it might be because the hood side panels were styled a bit longer at the front edge bottom, but figured you guys could set it straight (no pun intended!)
thanks
s.e.charles is offline   Reply With Quote
Old 05-16-2025, 11:08 AM   #5
petehoovie
petehoovie's Avatar
Old 05-16-2025, 12:32 PM   #6
Newc
Newc's Avatar
Radiator shops frequently get the replacement angle of the top tank wrong with 33/34 radiators. I make a light wooden mandrel [original rads] to check the top tank angle. fits on the back side of the rad under the top tanks. Share your mandrel with the rad shop doing your rad. Newc
Newc is online now   Reply With Quote
Old 05-16-2025, 04:35 PM   #7
highbeams
highbeams's Avatar
So . . . tilt it a half inch!
highbeams is offline   Reply With Quote
Old 06-06-2025, 11:32 PM   #8
Death Row Dave
Death Row Dave's Avatar
One of the toughest jobs I have attacked in a while . Aligning a 33-34 hood and grill . This is a tough one or it was for me
Death Row Dave is offline   Reply With Quote
Old 06-07-2025, 01:32 PM   #9
rich b
rich b's Avatar
Last one we did needed a little tune-up on the leading edge of the hood tops. Still needed flat black on rear lip of the grille before the lacing was installed; we used vinyl wrap instead of paint.
rich b is offline   Reply With Quote
Old 06-07-2025, 01:42 PM   #10
s.e.charles
Q: if i read yellow/ black/ chrome/ black/ primer - where is the vinyl wrap?
(sorry if i don't know if the chrome is chrome, stainless, or nickel)
i'm lost by the irregular black on the yellow tape.
thanks,
sid
Old 06-07-2025, 04:14 PM   #11
petehoovie
petehoovie's Avatar
Old 06-07-2025, 06:14 PM   #12
rich b
rich b's Avatar
thanks,
sid
Think the irregular "black" is just a reflection off the chrome that is not covered by chunks of yellow tape securing the poster board to the grille. I had further masking when I was tack welding the pieces onto the hood which had been removed in this picture.
The area I covered with matte black wrap was from just down a bit on the raised area of the grille and all the way to the back edge of the grille.
The idea is to make the gap between the chrome of the grille and edge of the hood top and sides be not as noticeable (area between the arrows in this picture).
Old 06-07-2025, 06:35 PM   #13
petehoovie
petehoovie's Avatar
