Old 10-22-2018, 03:26 PM   #1
Cape Codder
Cape Codder's Avatar
Default Changing Heads Original / High Compression
For those of you that have changed Heads can you tell me if changing from original to high compression requires longer bolts? If so how much difference in thickness is the two?
Thanks for your time.
Cape Codder is offline   Reply With Quote
