10-15-2018, 04:39 PM | #1 |
Greetings from New Zealand.
I've just put one of these in my shed for a bit of a project. Looking forward to getting underway. |
10-15-2018, 04:58 PM | #2 |
Re: Greetings from New Zealand.
Greetings from Arizona. I'm new here too. Nice car
10-15-2018, 05:20 PM | #3 |
Welcome!! Love 55/56's..............
10-15-2018, 06:26 PM | #4 |
Nice car. Which engine and transmission you have?
10-15-2018, 06:29 PM | #5 |
That car looks very straight and original. I like it!!
10-15-2018, 06:47 PM | #6 |
10-15-2018, 07:19 PM | #7 |
Yes, VERY original.
Its had newer rockers patched over the originals. Unfortunately that won't wash with the authorities here in NZ so they will be coming out and getting replaced. The only bits that are not straight are; outer rocker skins The front cross member has been replaced and one of the brackets is poorly repaired. There is a patch left side of the tail pan and the cross member beneath has rotted away. There is a hole in the left rear wheel well behind the front section of the quarter panel. There is a patch in the the left rear quarter panel |
10-15-2018, 07:27 PM | #8 |
Congratulations on your new project. These are great looking cars. |
10-16-2018, 01:59 AM | #9 |
.....And there is rust in the bowls. Glass bowl, glass bowl on the fuel pump and in the fuel bowl of the carb... tank is rusty.
there is a bit of fuel starvation too... |
10-16-2018, 02:03 AM | #10 |
Can someone please help me Identify this distributor?
I don't think its original. The vacuum source is off the front outlet of the teapot. |
10-16-2018, 08:08 AM | #11 |
Sweet '56! The '55 & '56 Fords are eye candy
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
10-16-2018, 08:56 AM | #12 | |
There will be STAMPING ID Nos on it for positive identification.
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - |
10-16-2018, 09:00 AM | #13 |
You know, it is a bit cruel to hide such a beautiful car just because it has mild cancer.
It needs the sunshine and fresh air ...
10-16-2018, 11:23 AM | #14 |
As Kultulz said, with the '57 and later distributor design, if it has the original type Holley 4000 teapot 4 barrel carb, the vacuum signal to the dist. advance will not be strong enough, unless someone modified the carb for ported manifold vacuum to the distributor, which is pretty easy to do. If the distributor vacuum port on the carb is still in the original location (high up), then it probably has not been modified.
Sal |
10-16-2018, 11:57 AM | #15 | |
The vacuum pressure level from an unmodified '56 teapot carb won't correctly operate the timing advance mechanism of a newer distributor. Last edited by dmsfrr; 10-17-2018 at 06:48 PM. |
10-16-2018, 12:58 PM | #16 |
Thank you everyone.
I'm tearing down the holley tonight to clean it out. I see if I can see the vacuum sources. There is a block on the back of the carb that went to the wipers that looks to be below the throttle plates. The fuel tank is out and getting its rust removed. The lines appear okay. The mech fuel pump is also getting looked at as I had to use a electric pump to get some fuel into the carb. The car runs okay but as soon as you get on the gas to go up a slight incline it acts like it starving for fuel. If look at the flow to the bowl and it's just a trickle. Looks like the float and needle are not adjusted right. |
10-16-2018, 01:00 PM | #17 |
10-16-2018, 01:06 PM | #18 |
The FLOAT level on your carb should be 1/4" below the gasket surface of the bowl at the toe of the float. That should get you very close to the correct FUEL level of 1/2".
If you need any help with any of the carburetor issues, I can help via email or Ford Barn messages, or over the forum posts. If you are not familiar with the teapot 4 barrels they can be a little tricky. Sal [email protected] |
10-16-2018, 01:11 PM | #19 |
There is also a fine screen located behind the brass fuel inlet fitting on the carburetor. It could be plugged with contamination, or even missing. There is supposed to a spring behind it to hold it in place against the brass inlet fitting.
Sal |
10-16-2018, 03:27 PM | #20 | |
Cheers Geoff |
