Old 10-08-2018, 04:58 PM   #1
A Model Man
Default Low compression on cylinder 2 & 3
I have about 5000 trouble free miles on a rebuilt standard Model A engine. Recently on tour the engine lost power but continued to run. Compression on warm engine is near 70# on front and rear cylinders but less than 50# on the two in the middle. Removed head, the gasket did not appear to be blown and valves were not stuck and appeared to be operating properly. Could not see any cracks in the head or block. Checked flatness of head and block with a straight edge and feeler guage and they do not appear warped. Filled headless engine block with coolant and there is no leak down of coolant. Installed new copper head gasket and torqued head appropriately to 55 ft/lbs. Rechecked compression and there was no improvement. I am puzzled. Anyone have a similar experience that might give me a next step to pursue?
A Model Man is offline   Reply With Quote
Old 10-08-2018, 05:08 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Low compression on cylinder 2 & 3
Did you lap and adjust the valves while the head was off? You could make a fitting and add air under pressure to a faulty cylinder and see if you can hear it escaping out the carb, other cyl., or exhaust pipe.
Old 10-08-2018, 06:56 PM   #3
FordTudor1931
FordTudor1931's Avatar
If you try the compressed air approach, don't forget to check if air is escaping through the crankcase vent pipe (oil pipe). It could be a bad ring causing the low compression.
FordTudor1931 is offline   Reply With Quote
Old 10-08-2018, 08:17 PM   #4
A Model Man
Lapping the valves may be my next step. I thought it unlikely to have sudden valve problems on adjoining cylinders simultaneously but I guess it could happen. They appear to be closing properly but appearances can be deceiving.
Old 10-08-2018, 08:21 PM   #5
Bob C
Did you put some oil in the cylinders to see if the compression came up??
Bob
Old 10-08-2018, 08:58 PM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I’m thinking it’s in the head or block, possibly causing a gasket problem. Before tearing it apart again, do a leak down test. Pretty sure you’ll find a problem common to those two cylinders. Be sure and have all the plugs removed.
Old 10-08-2018, 09:01 PM   #7
Dick Steinkamp
Dick Steinkamp's Avatar
I wouldn't try any fix until I knew what the problem is. You will only confuse the issue.
See post #2 and #3 for the initial diagnosis. If it comes up that air is leaking past the valves, I would adjust them first, then test again.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 10-09-2018, 11:02 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
"Maybe" just a DRY head gasket blow, between #2 & #3?
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-10-2018, 02:45 PM   #9
100IH
I totally agree with the post#7. Spending$$$ on parts and labor before exhausting available diagnostic procedures is asking for a ticket to do it again. Cylinder leakage test also known as leak down test has been around before the model A. If your new to this, OK good, it will teach you how to visualize the compression elements better than anything else. Do the searches and make the tool. You'll never regret it.
100IH is offline   Reply With Quote
