#1 |
What effects, if any, would the engine have if I put in a spacer between the Exhaust/Intake Manifold and the side of the block?
I am unable to install my exhaust manifold heater cover since I had the motor rebuild. The block was faced in the exhaust/intake manifold area as was TWO exhaust manifolds. Any idea's? |
#2 | |
![]() Quote:
Effectively none if the spacer does not set up any reversion effects. Port matching is the key there along with a way to pin it using manifold studs or ??. Can the manifold cover be machined a little thinner as an alternate method to allow it to fit. |
#3 |
I was thinking of that Brent BUT as of now, I haven't been able to determine how much I would have to take. Thanks for your response and suggestion!
#4 |
Can you try two gaskets to see how much you need to take off then take that much off the exhaust heater
#5 |
Mr. Gasket makes a very thick gasket intended for headers..
#6 |
Thanks again. |
#7 |
Instead of all that work, why not just grind some of the bottom of the heater cover away?
#8 |
Sorry. I didn't see that was already suggested.
