Old 09-13-2018, 10:56 AM   #1
30 Closed Cab PU
Default Sediment Bowl Screen
Last year my A was running a little funky. Saw there was grit in the sediment bulb. So removed it, wiped off the screen, inspected the screen with out backlighting it, seemed OK. Cleaned the gas petcock screen. Turned the gas back on and noticed the bulb took minutes to fill. So removed the bulb again inspected the screen and it looked plugged, but what ever plugging it looked clear, cleaned with brake clean and blew it out . Issue solved.
Curious, any ideas on what was in my screen?
30 Closed Cab PU is offline   Reply With Quote
Old 09-13-2018, 11:50 AM   #2
ryanheacox
ryanheacox's Avatar
Default Re: Sediment Bowl Screen
Old gas tank sealer? Just a guess
ryanheacox is offline   Reply With Quote
Old 09-13-2018, 12:31 PM   #3
30 Closed Cab PU
It was like a clear varnish, extremely thin. I thought that too, looked in the tank, unless it is extremely thin and clear, does not appear to have sealer.
