Old 01-06-2011, 10:48 AM   #1
Flathead Fever
Flathead Fever's Avatar
Default Ford Flathead Manual Cooling Tip
I was going through some of my Early Ford literature and I ran across this Flathead rebuilding manual. This is a great little factory shop manual for rebuilding the Ford flathead, lots of good photos. I see these on ebay all the time, if you don't have one I would pick one up.
One of the things it mentions is having to modify earlier heads to fit a 59A block and modifying earlier heads for better cooling (see photos).
Flathead Fever is offline   Reply With Quote
Old 01-06-2011, 10:57 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Ford Flathead Manual Cooling Tip
That is very interesting. Thanks.
Old 01-06-2011, 11:29 AM   #3
Bruce Lancaster
If you read that, you will note that the old trapezoid-hole gakets, still sold by some places even for later engines
Bruce Lancaster is offline   Reply With Quote
Old 01-06-2011, 11:58 AM   #4
Bruce Lancaster
...are utterly obsolete fro even the prewar applications, which are to be redrilled for the 59 type. People are still buying them, and catalogs are offering them without application info.
Old 01-06-2011, 12:10 PM   #5
Coupe35
Can not make out the pictures very well, but if it talks about enlargeing the 2 middle holes, I tried that and I could not tell any difference in the cooling.
Coupe35 is offline   Reply With Quote
Old 01-06-2011, 12:15 PM   #6
ken ct
Ford also put out a red cover one on fuel systems and one on electrical componants yellow cover and a black cover one on trany an rear ends.I have them all. ken ct. I think the fuel one is the hardest to find.Ive never seen another one but the one i have.
ken ct is offline   Reply With Quote
Old 01-06-2011, 12:16 PM   #7
Old Henry
Old Henry's Avatar
The difference would not show up on the tempreature gauge. I just cools the heads better.
Old 01-06-2011, 12:26 PM   #8
Bruce Lancaster
Fuel System, Generator and Starter, transmissions and overdrives, 4, 6, 8, and 12 cylinder engine overhaul books (4 is N type), 8 cylinder is around in 3 or 4 updates I have not really compared.
One of the books lists and gives form numbers for ignition, passenger rear axle, and front end and steering books...but I have never seen those in 40 years of hunting and neither has any other collector I have met, and I do not believe they were ever actually released.
They go nicely with '46 Service manuals. I have found Canadian versions of several of these books.
I also found a small roughly 4 inch thick Ford binder, marked in gold "Ford manuals, operator, service repair" over oval logos...it holds the whole bunch, a stack of '40's owner manuals, and the service volumes nicely and was probably made for this set. Ford didn't publish much else in this size.
Old 01-06-2011, 03:15 PM   #9
Flathead Fever
I tried scanning just the picture of the heads and gaskets at 800X600 dpi so the pictures should show up bigger for you.
Old 01-06-2011, 03:45 PM   #10
bobscogin
I'll soon be installing the heads on my '42 Merc "99" with 29A heads. This block has the trapezoidal upper and lower holes in the deck, but the center one is round. What mods do I have to do to these heads to work with the later head gaskets? Drilled as shown in this thread, or different?
Bob
bobscogin is offline   Reply With Quote
Old 01-06-2011, 03:55 PM   #11
jerry grayson
Bruce
I have some of these books also and the one that covers "repair manual Ford and Mercury V8 engines" says on the inside second page that "this book is one of a series of eleven illustrated repair manuals etc". I do not have all eleven and have never seen all of them. I do have a thick binder like you describe that has same size books for 1958 through 1960.
I have never seen the fuel system manual.
jerry grayson is offline   Reply With Quote
Old 01-06-2011, 05:00 PM   #12
Bruce Lancaster
Fuel system manual (I have Canadian and USA) gives you nothing much that isn't in the Service Bulletin overhaul pages, so you are missing a collectible but not actual information.
I am well nigh certain the the books I don't have were never published...I've talked with Ford paper nuts even crazier than myself, and all agree they are not around.
The others were quite common 20 years ago. I think V8, V12, and transmission ones are the only ones reproduced.
Old 01-06-2011, 05:03 PM   #13
jdl
jdl's Avatar
Send a message via ICQ to jdl
Larger size.......jdl
jdl is offline   Reply With Quote
