#1 |
I have saved a picture of one of those, it allows one to get the cab squared up (mine was found in a holler lol). It is out of square and I have the measurements from most points on the truck. Going to take off the roof, doors and all windows, etc. and put it on a table to get everything where it's supposed to be.
Looking for advice from those who have used this method. Do I make a steel frame first, then build the wood around it, or just use wood? And I'm going to use caster wheels under it for mobility. I'm thinking maybe build out of some kind of hardwood and put casters on...Suggestions? |
#2 |
I'm making one out of 2x4's. Obviously picking up on the mounting points of the cab. Using construction screws for the frame and adjustable scaffold wheels to allow for leveling. I screwed blocks on each corner for leveling points. That allows me to wheel it around and level it whenever I work on it. I plan on using the frame once, so when I'm done, I'll disassemble it and use the wood on something else or just burn it.
#3 |
