Old 08-26-2018, 04:41 PM   #1
31steve
Default Engine ID needed
Hope someone can ID this T head, Rayfield carb, no other ID. Thanks, steve
31steve is offline   Reply With Quote
Old 08-26-2018, 05:34 PM   #2
nhusa
nhusa's Avatar
Default Re: Engine ID needed
Doesn’t look like a Model T Ford to me
nhusa is offline   Reply With Quote
Old 08-26-2018, 11:07 PM   #3
40 Deluxe
I see some new parts on it. Does it run? Definitely not Model T!
Old 08-27-2018, 08:59 AM   #4
redmodelt
redmodelt's Avatar
Because of the location of the oil/water pump and no way to mount a fan it might have been for a boat (maybe). You might try asking over here;
https://www.smokstak.com/forum/forumdisplay.php?f=38
As it looks to have a pulley on the back, could have been a stationary engine running a belt line in a shop or ?
Old 08-27-2018, 01:07 PM   #5
24ruxstel1339
24ruxstel1339's Avatar
My guess is it started out as an early MC or aircraft engine.
Definitely early, teens possibly, not Model T, or any other Ford I've ever seen.
24ruxstel1339 is offline   Reply With Quote
Old 08-27-2018, 01:15 PM   #6
31steve
I have not tried to run it as I have to fabricate water outlets first. I cannot find a similar engine in Google or the auto forums. Had it looked at by a group of early boat engine restorers and they thought it was not a marine engine. Thanks for the input! Steve
Old 08-27-2018, 07:05 PM   #7
redmodelt
redmodelt's Avatar
Well how early of boats were these guys working with, I would say this motor is from the teens. Smokstak has a lot of different sections. One might be a better fit then others or try one of the national antique car clubs.
Old 08-28-2018, 03:20 PM   #8
31steve
Thanks, I have it on the AACA and smokestak both.
Old 08-28-2018, 06:19 PM   #9
redmodelt
redmodelt's Avatar
31steve, which section in Smokstak? I would like to follow over there and see what they come up with.
I found it. There a bit more info if you got it from a guy named Tim
https://www.smokstak.com/forum/showt...light=Rayfield
There was a link to above in your posting over there.
Old 08-31-2018, 05:18 PM   #10
gulfoil
Tim was the previous owner. We did a trade at Portland.
gulfoil is offline   Reply With Quote
Old 08-31-2018, 07:42 PM   #11
tinman080
tinman080's Avatar
Looks a LOT like a 1910-15 REO engine....
Just Passin' Thru.....Slowly!
tinman080 is offline   Reply With Quote
Old 09-02-2018, 07:53 PM   #12
31steve
Sure does but the carb and mag are on opposite sides on mine.
