05-21-2010, 02:36 PM | #1 |
39 Master Cylinder Throw ?
Guys,
Can someone tell me what the throw distance is on a 39 master cylinder? Assume avaerage brake adjustment. TX, Peder |
05-21-2010, 04:17 PM | #2 |
Re: 39 Master Cylinder Throw ?
I never measured the "stroke" but when it returns the back of the piston has to clear the small hole you can see down in the bottom or the brakes hang up. G.M.
www.fordcollector.com |
05-22-2010, 06:50 PM | #3 |
I think the full stroke on a '39 Master Cyl is one inch. I should think that the brakes should be full on (panic stop) at no more then 2/3 (pedal) stroke. If you are dealing with new brakes, you may have to fully get them beded in before you can get the proper adjustment.
What is your application? If you are having trouble getting proper adjustment and you are dealing with a non-stock application and not a stock '39-'48 Ford or Merc., you may have to re-visit your installation. There is a lot involved with proper lever lingths and linkage with a "custom" brake installation. Let us know what you are dealing with. Chris. Last edited by CWPASADENA; 05-22-2010 at 06:53 PM. Reason: CLARIFICATION |
05-23-2010, 12:26 AM | #4 |
I'm doing a hyraulic conversion on a 35 coupe using a 39 master cylinder. I think that I have it pretty much figured out but needed the throw distance to set up the lever arm that will be pushing on the MC. The 1" helps.
Thanks much, Peder |
05-23-2010, 04:36 AM | #5 |
Why don't you just measure the stroke on the '39 master? Then you will know for sure before trying to set up pedal linkage.
05-23-2010, 08:59 AM | #6 |
