Old 08-19-2018, 01:29 PM   #1
CaliforniaBorn36
CaliforniaBorn36's Avatar
Default 1941 Shock Mounting Bolts - Size, Grade and Source?
1941 Ford 1/2 Ton Pickup.
Want to verify, and check for source on front shock mount bolts. Mine are missing, but it looks like maybe a 7/16" x 1-1.2 inch carriage bolt. Would that be correct?
Should be Grade 5 or 8?
Does anyone know a source that is not a box of 50? Restoration parts houses don't list them online and big box stores do not seem to carry this size?
Thanks,
CaliforniaBorn36
CaliforniaBorn36 is offline   Reply With Quote
Old 08-19-2018, 03:23 PM   #2
Mart
Mart's Avatar
Default Re: 1941 Shock Mounting Bolts - Size, Grade and Source?
I imagine they may be available. (Roy Nacewitz?). Funny enough I found some good quality 7/16 UNF carraige style bolts here in the UK. They have a massey Ferguson logo on them. Try doing a search on ebay. If no-one chips in with a known source of the proper parts, you might find some generic parts like I did. Prior to that I had improvised by using some modified wheel studs.
Mart.
Old 08-19-2018, 04:24 PM   #3
40fordpu
40fordpu's Avatar
Second that on Roy. Fordscript.com I believe. Good guy. Give him a call or have someone check the bible - might be in there.
40fordpu is offline   Reply With Quote
Old 08-19-2018, 07:35 PM   #4
TJ
TJ's Avatar
fordbolts. com
Old 08-19-2018, 09:17 PM   #5
JSeery
JSeery's Avatar
Green book list 7/16-20 x 1 1/4
