Old 08-04-2018, 07:17 AM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 59A Oil Filter
So this 59A engine is fitted with the cannister type oil filter. Filter insert dimensions: 4 3/4" by 4 1/4". Is there some recognised parts No for these?
Like a Wix filter No or similar.
Thanks,
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 08-04-2018, 07:32 AM   #2
big job
big job's Avatar
Default Re: 59A Oil Filter
I use Napa #6006 for my 8BA's I should think it should fit the 59A's not sure cause my
59A has no filter= wish it did
big job is offline   Reply With Quote
Old 08-04-2018, 07:32 AM   #3
51504bat
51504bat's Avatar
Wix 51006 if its the stock oil filter canister.
Old 08-04-2018, 07:57 AM   #4
Phil Gillespie
Thanks for that. We dont have Napa here in this country, but will try for the Wix info as below.
Many thanks,
Phil NZ
Old 08-04-2018, 07:59 AM   #5
Phil Gillespie
Yes its the stock unit so this should assist.
Thanks
Phil NZ
Old 08-04-2018, 08:05 AM   #6
fordwife
As I recall the 8BA and 59A filters were the same. Purolater # was P34.
fordwife is offline   Reply With Quote
Old 08-04-2018, 09:20 AM   #7
42merc
42merc's Avatar
Fram - C4 also works.
42merc is offline   Reply With Quote
Old 08-04-2018, 04:37 PM   #8
Ronnie
Ronnie's Avatar
c4 fram lf101 Hastings 51006 Wix p41 Baldwin lf130 Hastings 1006 Napa
l30034 Purolator p4 lubrifiner fleetguard 510
That should keep you busy
R
Ronnie is offline   Reply With Quote
Old 08-04-2018, 07:29 PM   #9
Phil Gillespie
R
Thanks for all those cross references. Here in NZ hopefully now can pick up one for the job.
Phil NZ
Old 08-04-2018, 09:03 PM   #10
34pickup
34pickup's Avatar
I just went to O'reillys auto parts and they looked up the part number and had it in stock.
Oh, just saw where you are. Guess there are no O'reillys there.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 08-05-2018, 02:04 AM   #11
Phil Gillespie
So I drained oil and removed oil filter for check to replace.
Its fitted with a Wix PC-1-F which I guess isthe equivalent of other brands as advised
Phil NZ
Old 08-05-2018, 02:40 AM   #12
flatheadmurre
flatheadmurre's Avatar
Today the car parts stores usually donīt have them at hand...but a good agricultural/heavy equipment store has them.
Deutz, Merceds om314/616/621, Allis Chalmers, Hough, Hyster, Case...a company dealing with deutz usually have them on the shelf.
Old 08-05-2018, 03:53 AM   #13
Phil Gillespie
Yes you are right. The average car parts stores do not have these here.
So will go with as you suggest the heavy equipment outlets or filter outlet specalists. They are on ebay but when shipping is figured price really goes up for the landed filter in NZ.
Phil NZ
Old 08-05-2018, 04:27 AM   #14
fordlovr
fordlovr's Avatar
Hi Phil, I suppose you will put up a couple of pic's of the new V8?
fordlovr is offline   Reply With Quote
Old 08-05-2018, 08:31 AM   #15
RKS.PA
RKS.PA's Avatar
Here's a somewhat related story. I also needed a 51004 and was at Walmart for some other stuff. So, I asked the manager about the filter. He checked his inventory, found nothing, picked up the phone and called the local O'reillys! Yup, they had it and saved it for me!
Just giving credit where credit is due!!!
RKS.PA is offline   Reply With Quote
Old 08-05-2018, 11:27 AM   #16
Phil Gillespie
Yes Bryn,
It came off Trade Me,a green 1946 Mercury Coupe, just got it last week from Mosgiel. Will get a couple of pics up.
Phil
Old 08-05-2018, 11:56 AM   #17
mike42
mike42's Avatar
Just replaced mine with oil change and NAPA #1006 is the one I use. It comes with 2 oil rings depending on what canister you have. Mine's a '40 V8. I've been buying this one for several years.
Mike
mike42 is offline   Reply With Quote
Old 08-05-2018, 07:06 PM   #18
Phil Gillespie
[QUOTE=Phil Gillespie;1659538]Yes Bryn,
Phil[/Quote
So pics. Depart Mosgiel the at Middlemarch through Macraes Flat through Palmerston and up main road to home. Battery went flat on camera so missed out on some nice Central Otago pics.
Already played about with a few things such as: fuel gauge, temp gauge, starter circuit. A few more items to pick away at but generally runs well.
Phil NZ.
Old 08-06-2018, 12:05 AM   #19
Graeme / New Zealand
Graeme / New Zealand's Avatar
Yeah Phil that's one nice car I drooled over it when it was up on Trade Me. I see the PO has used back up up lights as indicators like I have just done...... it was my thought and i didn't copy LOL. Are your front ones running through the the park lights or the foggies?
About the filters, I was told they are the same as common fork lift ones so there is something to explore.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 08-06-2018, 12:18 AM   #20
Phil Gillespie
GB
Am in touch with Wix agent in Auckland who is on to it.There are 40 pcs across the ditch in Aus. Front ones are running through park lights. Fog lights are just for decoration and not wired up to date.
Of note there is fitted a vaccum tank in front of radiator for wipers, have only tested them and seem to work ok.
There is also a half fitted heater, just requires a few bits to complete.
For a sight unseen car its turned out ok.
Phil NZ
