#1 |
Will a round speedo instrument panel bolt up to a tank originally equipped with an oval speedo panel?
#2 |
No. The indent and nuts are specific to each instrument panel. Also, the dash rail structure is different(what the dash rail mounts on). So, if you changed to a later gas tank, the dash light for the round speedometer instrument panel will not "bolt up". You can cut the structured rail so that the dash light will mount.
#3 |
