Old 07-02-2018, 11:28 AM   #1
Bud
Bud's Avatar
Default Cabriolet Rear Window Frames
How does one tell the difference between an original 68C rear window frame and the currently available reproduction? I suspect the edges on an original are more rounded but I really don't know and would like to know the difference. Thanks.
Bud is offline   Reply With Quote
Old 07-02-2018, 06:53 PM   #2
Bud
Bud's Avatar
Default Re: Cabriolet Rear Window Frames
Anyone?
Old 07-04-2018, 12:33 PM   #3
Bud
Bud's Avatar
I am sure someone knows the difference. Please post a reply. Thanks.
Old 07-08-2018, 04:47 PM   #4
Ray in La Mesa
If I understand your description, you could be right. I have a '30 68B which ,I believe, has the same rear window as the '31 68C. I have both a LeBaron Boney repro and 2 originals. The originals have a slight rounded, convex on the face of both the inner & outer frames while the repro is flat across the faces of both frames. The radius of the corners is the same.
Ray in La Mesa is offline   Reply With Quote
Old 07-09-2018, 06:29 PM   #5
Bud
Bud's Avatar
Thanks Ray, exactly what I was interested in finding out.
