05-28-2018, 03:10 PM | #1 |
Rear Backing Plate Bolts
Pulled my rear drum on the tudor to check brake lining wear and axle bearings, and found a problem with the bolts/nuts that hold the backing plates on. It looks like there is a spacer or something missing, although I have checked the exploded drawings and everything looks to be in place.
I measured the bolts and they are correct as far as I can see - 1 17/32", 1 7/8". Both the short bolt and the long bolt are off by the same amount, not allowing the use of the cotter pin. Any thoughts? |
05-28-2018, 03:25 PM | #2 |
Re: Rear Backing Plate Bolts
Wrong grease baffle.
John |
05-28-2018, 03:39 PM | #3 |
Here are a couple pictures of the rear baffle on my 29 ccpu.
You can see they are different from yours, and they have the spacers between the backing plate and baffle The spacers are attached to the baffle.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
05-28-2018, 04:12 PM | #4 |
Deleted post
Deleted post
05-28-2018, 04:25 PM | #5 |
Dan,
I don't remember any spacers between the backing plates and the emergency brake carrier. I took some pictures of the baffle style I plan to use on the 29 phaeton and 29 CCPU. There is no spacers on any of the baffles and I have 4 of them. I don't know why the bolts appear to be too long. Maybe Dudley would know. It is a job to remove the rear hub to check the bolts/nuts on my coupe. I don't remember the cotter holes being past the slots in the castellated nuts when I assembled the rear end on the coupe. I vaguely remembered that when I was getting the rearend mounting fasteners cad plated there were 2 sizes of the nuts. I dug through my rearend goodies and found the 2 different lengths. I have no idea why there are 2 lengths. Maybe that is part of the problem you are having. If I were you, I would slip some lock washers under the nuts, as I think you have everything correct. Rusty Nelson |
05-28-2018, 04:25 PM | #6 |
https://www.fordbarn.com/forum/showthread.php?t=241062
05-28-2018, 04:32 PM | #7 |
Searched "rear brake baffle" and it seems that the early baffles had 3/8" washers/spacers spot welded on the back side of flat back baffles. Later baffles had stamped 3/8" spacers. My early 28 Tudor had the spot welded spacers. I installed modern shocks and had to replace the baffles to accommodate the shock brackets and be able to use the original bolts. I can't find anything concerning the different grease baffles in writing or parts books other than Ford Barn thread search.
John |
05-28-2018, 04:35 PM | #8 | |
05-28-2018, 04:37 PM | #9 |
The attached article may be of help.
Tom Endy |
05-28-2018, 04:58 PM | #10 | |
Re: Rear Backing Plate Bolts too long - backing plate bolts too short
Also has links to additional info. The question was answered on MARCH 18th 2018 as 1955cj5 mentions in this # 6 post above. Details are in posts #6 and 10 as mentioned. Last edited by Benson; 06-11-2018 at 10:09 AM. |
05-28-2018, 05:28 PM | #11 |
What great answers. A perfect example from all respondents of how helpful replies can be.
Nobody said "look up the judging standards" or "do a search its been answered before" Also Interesting how I had to edit my own post here so it could not be misunderstood as sarcastic or snarky by accident!. I should have made this a new subject quoting the old post but I don't know how to do it on my tablet. SAJ in NZ Last edited by SAJ; 05-28-2018 at 05:30 PM. Reason: Reworded so did not sound sarcastic |
05-28-2018, 05:37 PM | #12 |
An aside note:
If you order the new baffles AND the new bolts from Berts you get the correct shorter bolt set that fits the newer stamped baffles. I had a set of the older baffles and had to find some of the old longer bolts in the "old bolt bucket". |
05-28-2018, 07:59 PM | #13 |
I see another possible area of confusion here.
There are two different sets of bolts involved here as we discussed. 1. The long set for revision 1 baffles with the sleeves spot welded to the baffle. 2. The short set for new stamped revision without sleeves. EACH set has two bolts that are longer than the other two. https://parts.modelastore.com/show_Product.asp?ID=3157. In each set the longer bolts fasten the RADIUS arms to backing plate. |
05-29-2018, 09:37 AM | #14 |
Thanks everyone! I see this morning I posted to the other thread.
https://www.fordbarn.com/forum/showthread.php?t=241062 |
05-29-2018, 11:18 AM | #15 |
Dan,
I think the one's with the spacers crimped/tack welded on are e-28...left hand E-brake. I'm 99.9% sure. The fronts will be the same way....I think it goes with the early drums. Also,...the bolts are different lengths.....early vs. late.. |
05-29-2018, 11:52 AM | #16 |
I agree with Dudley. I have an early front end (round mounting front spindles) that has the spacers attached to the grease baffles.
Rusty Nelson |
05-29-2018, 04:29 PM | #17 |
Here's a photo of an early '28 rear grease baffle. Note the spacers behind the nuts.
I'm trying to figure out if I have this installed correctly; that's a different thread. |
05-29-2018, 04:42 PM | #18 |
You have them inside out(too catch the oil and grease) AND it needs to be turned 90
degrees...so it drains out the hole in the backing plate.. |
05-29-2018, 05:11 PM | #19 |
Thank you!
I got this car in boxes. And I'm finding a paucity of literature on details like this. |
05-29-2018, 05:19 PM | #20 | |
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 05-29-2018 at 05:26 PM. |
