Old 05-11-2018, 09:46 PM   #1
Tom Bellfoy
Tom Bellfoy's Avatar
Default need to change position of tie rod on steering
I need to reverse position of tie rod on my spindle from top to bottom on a steering conversion job. The Ford spindle I am using will accept a tie rod from the top and I need to reverse it so that I can attach the tie rod the opposite way in order to clear the wishbone. in other words the taper is the wrong way.
How can this be accomplished ? what are my options. The steering spindle and king pins can be easily moved.
A close measurement now is .533" on bottom and top is .596
I need to reverse this
Will a ball joint reamer do the job ?
Tom Bellfoy is offline   Reply With Quote
