Old 05-05-2018, 11:53 AM   #1
B-O-B
B-O-B's Avatar
Default spark plug wires
Just got this 59A-B going with all new internals cept for the reconditioned rods ,turned 3 3/4 crank, & reground cam to L-100 specs. Heads milled & block squared & decked. It fired right off but with no cooling I shut it right down. Just had to see if it would. Kinda tight for the 6V starter tho. It originally had a helmet dizzy & wire conduits with these 7 MM hi-performance solid core wires. I would prefer to use the carb that I installed but the wires are just a weee bit short to use with the wire conduits. I can find the cloth woven wires.
This engine came from a 39 ford race engine & I would like to keep some resemblance of it. I didn't get the heads but a have dual intake that will be installed sometime in the future.
Going to replace the tired 21 stud in my 34 roadster.
File Type: jpg 17155764_10211770242953580_1667796107943540073_n.jpg (73.5 KB, 59 views)
B-O-B is offline   Reply With Quote
