#1 |
The two mounting bolts for the headlights on my '36 are 11/16 diameter. I'd like to get the correct 11/16" split lock washers for them, but nobody seems to carry them. I've tried parts old Ford suppliers such as MAC'S, C&G, Ray Nacewicz, etc., as well as Fastenal, McMaster-Carr, etc. - nothing.
Does anyone know a supplier for these lock washers ? Thanks, -Bob |
#2 |
Maybe you could make your own by cutting one side of a flat washer and bend it in the correct direction. Just a thought.
#3 |
18 mm is a little larger ---or even a 3/4, cut a little off one end and close it to size in a vice
#4 |
If you mean 11/16 inside diameter I have 1 extra as pictured, wish I had 2 for you. Have 2 extra nuts though.
#5 |
It's possible that someone like Little Dearborn, barnfind08, the V8 Shop in CA, or the guy that used to work at Joblot and opened his own business might have one. I may even have a used one that I would let go, but would need to check.
#6 |
#7 |
Did you try Roy Nacewicz at fordbolts.com?
#8 |
Bob C:
Right on the money. I looked through the MAC'S catalog and never saw them. Thanks, -Bob |
