05-04-2018, 02:16 PM | #1 |
Will a BB Bell work with a T5?
Wondering if a BB bellhousing would work adapting a T5 to a B block the same way an AA bellhousing works with an A block? I know you would have to use the B oil pan as well...
Or would it be better to adapt an A flywheel housing to the B block and use the AA bellhousing? |
05-04-2018, 03:06 PM | #2 |
Re: Will a BB Bell work with a T5?
You have to have wishbone and pedal adapters.
05-04-2018, 05:14 PM | #3 |
The pedal adapter should come with the bell housing to trans adapter since you would need it with the AA or BB bell housing.
Bob |
05-05-2018, 03:38 PM | #4 |
If going into an A, it will work but needs rear engine mounts, pedal mount, wishbone mount, etc. If going into a B, just needs rear trans/engine mount.
05-08-2018, 07:39 AM | #5 |
Thanks Jim! Forgot about rear engine mounts! I'll hold out for an AA unit!
05-08-2018, 01:29 PM | #6 |
