Old 04-29-2018, 01:25 PM   #1
nhusa
nhusa's Avatar
Default Steering wheel removal
I am rebuilding the steering box in a 31 Town Sedan.
I got the assembly (column and box) out of the car and am now taking it apart.
My problem is getting the wheel off the shaft.
I have the nut off, made a stand that goes to the floor and catches the flange on the steering wheel in two places and tried a hammer with a wood block to protect the threads.
Also tried a little heat and ice but it won’t budge.
I don’t want to purchase a Model A steering wheel puller for one job.
Does anyone have any suggestions
nhusa is offline   Reply With Quote
Old 04-29-2018, 01:54 PM   #2
WHN
Default Re: Steering wheel removal
Don’t be cheap, it could cost you more in the long run.
Buy, rent, or barrow a puller.
WHN is online now   Reply With Quote
Old 04-29-2018, 02:20 PM   #3
ursus
I purchased a puller from Bratton's to remove a stubborn steering wheel on my late 1931 coupe. I was unable to make it work because the gap beneath the wheel hub was too small to permit mounting the puller. I called Bratton's and was told to return it as this problem seems to occur often with the later steering column.
I was finally able to get the steering wheel off by dropping a red hot 3-inch bolt into the top of the column, leaving it in for a couple minutes, then quickly replacing it with another bolt of the same size that had been super-cooled in dry ice. The rapid shrinkage of the shaft relative to the hub taper allowed me to knock off the shaft with one solid rap on the top of the cooler bolt with a 3-pound hammer. The bolts used were of a diameter that just fit the shaft tube (can't recall the size).
ursus is offline   Reply With Quote
Old 04-29-2018, 02:39 PM   #4
nhusa
nhusa's Avatar
The hot and frozen bolt sounds like a great approach.
I’ll try it next weekend,
Old 04-29-2018, 03:07 PM   #5
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
https://youtu.be/er3gKmcWZJs
Here is a video that shows how I got a real bad one off.
If this link won’t open, just search YouTube for. Pulling off a stuck model a steering wheel.
Jacksonlll is offline   Reply With Quote
Old 04-29-2018, 03:28 PM   #6
nhusa
nhusa's Avatar
Jackson,
Thanks,
It is a great idea. I will try it before the heat and cool method.
Old 04-29-2018, 07:16 PM   #7
daren007
On my 30 there are two holes behind the light switch in the metal pieces that did not completely pass through. I finished drilling the holes and tapped for threads. A steering wheel puller easily removed the wheel using proper length bolts. No visible damage.
daren007 is offline   Reply With Quote
Old 04-30-2018, 12:57 AM   #8
CarlG
CarlG's Avatar
X2 post # 7
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-30-2018, 05:55 AM   #9
Growley bear
Ditto
Growley bear is offline   Reply With Quote
Old 04-30-2018, 11:28 AM   #10
Jim Brierley
Both of the above operations should work well. I usually pull the wheel before doing anything else. With both feet on the floor and knees pushing as hard as I can upwards on the wheel, the nut loosened and flush with the top of the shaft, I use a heavy brass drift and strike it with a large hammer. Sometimes it takes several whacks but have always been successful. The nut flush with the shaft protects the threads, the hammer shocks the wheel and shaft the brass drift allows a square hit on the nut. There is more than one way to skin a cat!
Jim Brierley is offline   Reply With Quote
Old 04-30-2018, 12:25 PM   #11
Gastrap
Gastrap's Avatar
Had to drill and tap mine. The dimples on the casting perfectly located the holes for the puller.
Gastrap is offline   Reply With Quote
Old 04-30-2018, 03:37 PM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
IF the steering is still in the car, SEARCH steering wheel removal & read my FOOL PROOF METHOD.
Bill Tricky
"THE ASSISTANT GURU OF STUFF"
Old 04-30-2018, 04:48 PM   #13
Mikeinnj
Mikeinnj's Avatar
Bill Tricky
Bill , Did the search and read the 500 most recent entries listed under your name but did not find it. Perhaps it is among some of the thousands of your entries that have been deleted in the past year or two.
Mikeinnj is offline   Reply With Quote
Old 04-30-2018, 05:55 PM   #14
CarlG
CarlG's Avatar
See next post . . .
Alaskan A's
Old 04-30-2018, 06:01 PM   #15
CarlG
CarlG's Avatar
Bill Tricky
Here's Bill's method that he posted Sept 2011:
I can help you! Sure fire way. Do it EXACTLY as I describe.
Screw nut partly on, sit with your feet planted on floor, grasp steering wheel at both sides, with elbows STRAIGHT, lean your upper body back STRAIGHT, ROCK YOUR UPPER BODY SIDE TO SIDE WITHOUT BENDING YOUR ELBOWS.The secret is that one arm pulls up on the wheel, while the other pushes down at the SAME time, and this will cause the taper to "POP" loose. I haven't had to use a puller since the '50's after learning this from an old pro!!
Be sure to have the nut partly on or you will surely get a nose bleed when it pops loose.
Alaskan A's
Old 05-01-2018, 07:33 AM   #16
BILL WILLIAMSON
Mike, SORRY you had to search SO MUCH, but it kept you off the streets & out of them BINGO PARLORS! Them OLD BINGO Ladies can be DANGEROUS!!
Bill Safeathomewiththedog
Old 05-01-2018, 04:10 PM   #17
Big hammer
Be sure to have the nut in place or you will get a bloody nose! I forgot the loose nut and became the loose nut :-)
get a bigger hammer tap done
Old 05-05-2018, 08:15 PM   #18
nhusa
nhusa's Avatar
Update
I finally had time to try again.
I used Jackson’s method including the plastic rope.
I put a bolt with a Allen head in the shaft to protect it.
At first I couldn’t keep the knot from slipping then I remembered that I used a match to fuse the frayed ends of a ski rope.
So I used a propane torch (I know a bit of overkill) to fuse the knot.
A couple of yanks on the tension bolt and a hit with a hammer — the wheel came off.
Then the biggest problem was getting the key out.
Thanks Jackson it worked perfectly.
