04-12-2018, 08:45 AM | #1 |
Zenith carb HELP
Hi guys, has anyone removed and replaced the brass plugs on the Zenith carbs? If so can anyone offer any advice. I bought 3 sets of plugs to try and do 1 carb. any help will be appreciated thanks THE HOOCH
04-12-2018, 11:27 AM | #2 |
Re: Zenith carb HELP
Good luck. It is tricky to get the plugs drilled out on center without getting into the cast iron. They can also be a bear to get swedged in so that they don't leak with out breaking the housings. What I do is to use wire and brake part cleaned to clean them, I use a small fiber optic on a flashlight to shine light down the passages to prove them open. If all else fails, then they get drilled.
Mark in MT Always looking for another opportunity to be wrong. |
04-12-2018, 11:40 AM | #3 |
Glass bead the passage ways clean, does a great job..
04-12-2018, 11:50 AM | #4 |
If you have not already drilled...Take the advice of the previous posters. You can easily damage the idle port when you drill out the plug associated with this passage. Follow this link to Tom Endy's Tech Article on cleaning the passages without drilling out the plugs.
http://www.santaanitaas.org/wp-conte...assageways.pdf I hosted a Zenith Carb Rebuilding Clinic last winter for about 20 Club members and we all used this method to clean the passages and we ended up with 20 good carbs. Good Day! |
04-12-2018, 11:53 AM | #5 |
Totally agree with you FM and Dave in MN..
The passages can be cleaned perfectly without removing the plugs.... Don't remove the plugs Sphooch ! |
04-15-2018, 03:41 PM | #6 |
