Old 04-09-2018, 04:46 PM   #1
Petty Cash
Petty Cash's Avatar
Default 28 RPU Back Cab Bracket Question
I am putting together my roadster pickup cab from new and original parts. The back of the cab has a bracket I need help with. How far down does this bracket go? What does the bottom part connect to? The frame or subrail?
I have attached a picture.
Thank you!
1929 roadster pickup original
1934 ford pickup rod
Petty Cash is offline   Reply With Quote
Old 04-10-2018, 01:48 AM   #2
Floats
Floats's Avatar
Default Re: 28 RPU Back Cab Bracket Question
Hi,
My RPU was also rebuilt from old and new parts by the previous owner.
Unfortunately that area was painted with underbody goop and covered with household underfelt.
I have attached a photo and highlighted the bracket with a Tippex marker. The bracket is riveted to a steel girder which seems to be part of the seat riser. The arrow points to where the LH bracket seems to be welded to the floor plate. The RH bracket is not welded.
File Type: jpeg A3E8E457-B247-4AFE-B6D2-F158F596535E.jpeg (124.0 KB, 33 views)
File Type: jpeg C6A7EDB6-5E1D-456F-ABD9-031A5F285030.jpeg (153.6 KB, 27 views)
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 04-10-2018, 09:06 AM   #3
Petty Cash
Petty Cash's Avatar
Floats,
Thank you. It looks like the bottom part is parallel with the horizontal bottom of the cab back.
I appreciate the help.
Tim
Old 04-10-2018, 10:11 AM   #4
Floats
Floats's Avatar
Hi Tim, yes,
I must admit, taking another look at my photos, they are not as good as I was hoping and the domestic underfelt really looks crappy. Unfortunately the RH bracket is totally covered with the underfelt. However, the position you are holding the bracket in your photo, seems perfectly correct.
Let me know if you need to see more.
Regards
Chris
