Old 04-05-2018, 12:12 PM   #1
myford7
Default Timing setup sequence.
I watched Les Andrew's videos on timing setup, which I used and it was great. However, I have one question (30 coupe). Les said that by adjusting the steering column, the control arm on the distributor should touch the body in full retard and then touch the body slot on the other side in full advance. He said this is very important for proper timing.
I can adjust the steering column so that the control arm will touch the distributor body in full retard; but when I pull the spark lever down to full advance, the control arm will not touch the body on the other side of the slot.
Car seems to run ok.
Any thoughts.
myford7 is offline   Reply With Quote
Old 04-05-2018, 12:19 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Timing setup sequence.
I wouldn't worry about it.
Old 04-05-2018, 01:11 PM   #3
1955cj5
1955cj5's Avatar
There is info here on the distributor body gap....it might help..
https://www.fordbarn.com/forum/showt...istributor+gap
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 04-05-2018, 01:13 PM   #4
burner31
burner31's Avatar
That's the way it's designed.
Touch the body on the up stroke, no need to touch body on the down, you will get all the adjustment movement needed
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 04-05-2018, 02:57 PM   #5
myford7
Thanks everyone. I went with touching on upstroke and not worrying about downstroke. Purrs like a kitten---or should I say a Ford Lion.
