Old 04-03-2018, 01:49 PM   #1
Tim Armstrong
Tim Armstrong's Avatar
Default 1930 station wagen, side curtain HELP
I have new LB curtains and fastners, none of the fastners are installed, can I find a pattern or outline of were they go? Hate to drill holes in a new wood body in the wrong place.
Tim Armstrong is offline   Reply With Quote
Old 04-03-2018, 07:30 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: 1930 station wagen, side curtain HELP
Use a needle to poke around through the fabric to find the holes.
Old 04-04-2018, 12:47 AM   #3
31 Woody
31 Woody's Avatar
Do the curtains already have grommets in them? If the grommets are located in the curtains, I would center the curtains up on the appropriate window openings and then mark the wood where the attaching pins go. If the grommets are not in the curtains, I would install the grommets first, then locate the attaching pins as previously mentioned. My reason for this is once the pins are secured to the wood, it is far harder to mark where the grommets get positioned and install them. If the wood has holes already and the curtains do not have grommets, do what Tom said.
Experience is a cruel teacher. It gives the exam first, then the lesson.
31 Woody is offline   Reply With Quote
Old 04-04-2018, 06:09 AM   #4
Tim Armstrong
My curtains and body have no holes in either.
Old 04-04-2018, 06:26 AM   #5
John
John's Avatar
The side curtains are shipped without holes as the original locations for the fasteners tended to vary a bit. The reproduction bodies are not drilled either. It is best to get a pattern from some generous original wagon owner.
John is offline   Reply With Quote
Old 04-04-2018, 07:19 AM   #6
Steve Wastler
Steve Wastler's Avatar
Just do a google search for images of ‘30 station wagons and you will see placement on other wagons, pick one you like, start with corners first then evenly space the ones between.
Steve Wastler is offline   Reply With Quote
Old 04-04-2018, 12:35 PM   #7
Slowplane
Slowplane's Avatar
Is your woody a 150A or 150B?
______________
Nothing Short of Right is Right
Slowplane is offline   Reply With Quote
Old 04-05-2018, 08:41 PM   #8
Tim Armstrong
Mine is a 150 B early 1930 model
Old 04-05-2018, 10:10 PM   #9
Terry Longest
Terry Longest's Avatar
Check with Tim Johnstone with Woody Wagons. He can provide correct measurements.
Terry Longest is offline   Reply With Quote
