12-26-2010, 07:49 PM | #1 |
Question on fuel pump for Weber
I have a down draft Weber set up on my A. My car is coughing under power. It was only occationally now it's very frequent. I changed the fuel filter with no improvement. If I change the fuel pump what psi should I install. There are 2 types at the local auto parts store. One is a 2 to 4 psi and the other is a 4 to 6 psi. Which one is recommended? If a new fuel pump is not the answer what else should I look at?
12-26-2010, 07:53 PM | #2 |
Re: Question on fuel pump for Weber
It does not take much pressure so the 2-4 psi is adequate however a quick question, .....is your vehicle a 6v or 12v? I have operated a "cheapo" 12v electric pump on 6v negative ground with great results where it was supplying two Holley 94 carbs. Generally speaking, the 6v pumps are more money so if a 12v pump will work for you, it could save you a few dollars.
12-26-2010, 08:11 PM | #3 |
I have one of the 12v fuel pump kits offered by the Model A suppliers that sell the Weber kits. It is, however, still in the box. Never got around to installing it since it has been working just great just on gravity.
12-26-2010, 08:41 PM | #4 |
