Old 03-15-2018, 07:33 PM   #1
FirstGenF2
FirstGenF2's Avatar
Default 51 F2 226 Project
For now, I have frame body and engine questions, this is my first ever project so I'm pretty clueless about the ins and outs of restoring a truck as a daily driver.
51' F2
45' CJ2a
FirstGenF2 is offline   Reply With Quote
Old 03-15-2018, 09:13 PM   #2
toby
toby's Avatar
Default Re: 51 F2 226 Project
Get a shop manual. It helps a great deal.
toby is offline   Reply With Quote
Old 03-15-2018, 09:47 PM   #3
Lanny
Lanny's Avatar
Ask away, there are lots of knowledgeable members here that are
willing and able to help, and answer most any question you have.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 03-16-2018, 09:34 AM   #4
41Joe
41Joe's Avatar
Those 6 cylinders are nice engines. Very hard to find aftermarket parts, very rare. I have an H-Series in my 41 and it is nice, and different.
41Joe is offline   Reply With Quote
Old 03-16-2018, 11:31 AM   #5
FirstGenF2
FirstGenF2's Avatar
I allready have and read most of the manual pertaining to the engine and frame, does anyone know where to get a rear crossmember because mine has a 90 degree bend in it
51' F2
45' CJ2a
Old 03-16-2018, 11:33 AM   #6
FirstGenF2
FirstGenF2's Avatar
My spring break starts today so im going to be spending the next 9 days straightenig and painting the frame, any tips for stripping rust? Is clr any good?
51' F2
45' CJ2a
Old 03-16-2018, 01:21 PM   #7
FortyNiner
FortyNiner's Avatar
Your first action will be to use protective gear - eye/breathing/hearing.
What kind of result are you after: driver, show, other?
Media blasting is the best choice for cleaning frames. There are a variety of media solutions available. Alternatively, wire wheels/brushes have their fans. Rust converters are popular for others. CLR is great for minor rust/mineral deposits on plumbing - not effective for this task. You absolutely need to get anything loose off the surface as part of your efforts.
You'll also need to decide on the finished surface: encapsulator (POR 15 or similar), powder coat (superior look and durability), or fancy paint to complete a certain look.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 03-16-2018, 11:38 PM   #8
FirstGenF2
FirstGenF2's Avatar
I'm currently working on the frame, getting it to bare metal with a wire wheel, and using por 15 to coat it when finished, I've tried some durability tests and that stuffs stronger than i thought it would be after one coat. im also heating and banging dents out on the cab and prepping to weld on a couple of replacement panels on the cab corners and bottoms of the fenders.
51' F2
45' CJ2a
Old 03-17-2018, 05:31 AM   #9
FortyNiner
FortyNiner's Avatar
Be certain to check the directions for your POR15 as some versions are prone to UV fade.
Old 03-17-2018, 07:03 PM   #10
FirstGenF2
FirstGenF2's Avatar
Your right I was planning on applying the top coat once I have the whole frame done with the base layer.
51' F2
45' CJ2a
Old 03-21-2018, 10:28 PM   #11
FirstGenF2
FirstGenF2's Avatar
Im looking into getting a material blaster to clear the frame and body sections but know nothing about them. any tips tricks/ reccomendations?
51' F2
45' CJ2a
Old 03-21-2018, 10:57 PM   #12
FortyNiner
FortyNiner's Avatar
You'll need a good compressor to feed it - the bigger the better. I bought the Harbor Freight sand blaster unit and it is serviceable. Protective gear is a must.
Might be worth checking Craigs List in your area.
Old 03-22-2018, 03:09 PM   #13
FirstGenF2
FirstGenF2's Avatar
how much did the harbor freight sand blaster run you? I don't need a massive one, just one to do the frame and some body panels, im going to harbor freight to price them out tomorrow.
51' F2
45' CJ2a
Old 03-22-2018, 07:45 PM   #14
FortyNiner
FortyNiner's Avatar
I bought the 100# version for about $100, back a few years ago. The smaller unit would be just as useful but needs to be refilled more often. The compressor needs to be at least a 40 gallon unit.
Old 04-04-2018, 11:38 PM   #15
FirstGenF2
FirstGenF2's Avatar
Anyone know of where to get the valve tools for the 226? I'm having a hell of a time trying to remove them with other tools.
51' F2
45' CJ2a
Old 04-05-2018, 12:10 AM   #16
flatheadmurre
flatheadmurre's Avatar
The later 226 doesn´t take any special valve tools...valve spring compressor get the keepers out and apart it falls.
Old 04-05-2018, 03:48 AM   #17
FortyNiner
FortyNiner's Avatar
Check with Van Pelt Sales on the tools.
Old 04-05-2018, 08:07 AM   #18
edhd58
edhd58's Avatar
The parts readily available for the H 226.
edhd58 is offline   Reply With Quote
Old 04-05-2018, 11:24 AM   #19
41Joe
41Joe's Avatar
I used a standard valve spring compressor when I did mine.
Like this:
https://www.amazon.com/Neiko-50602-V.../dp/B002GQEZH0
Old 04-05-2018, 09:16 PM   #20
FirstGenF2
FirstGenF2's Avatar
The 51' has the rotating type valves with a (seemingly pressed on) sleve over the locking keys, how do you go about removing this without doing to much damage overall. and also tips on re installing the rotating type valves would be helpful.
51' F2
45' CJ2a
