Old 03-03-2018, 01:41 PM   #1
Trekemeyer
Default 1938 Ford Pickup Exhaust Manifolds
Has anyone used center drop exhaust manifolds on a 1938 Ford pickup truck? After looking at my truck, they don't appear to have enough clearance with the steering box. I would like input as to what to use and would be interested in buying an exhaust manifold setup. Mine is a flathead motor and am running a stock frame and front end.
Trekemeyer is offline   Reply With Quote
Old 03-03-2018, 06:31 PM   #2
39portlander
39portlander's Avatar
Default Re: 1938 Ford Pickup Exhaust Manifolds
According to the 38-39 book the same pair of exhaust manifolds were used 78-9439/9431, these may be the same for the commercial (trucks). There were some "experimental" 91A engines and it is currently unknown what those 500 or so were like, more Ford folklore.
Pictures would be helpful, also what is the flathead. My 39 had a 59AB and have those manifolds taking up space somewere. I resurrected my truck with Reds headers and those sweet sounding Smithy's
Not sure were you are located but the spring swap meets you may want to try. If I locate my old manifolds and they're not what you already have, you can have them, just pay for shipping. Scott
39portlander is offline   Reply With Quote
Old 03-03-2018, 09:31 PM   #3
Tinker
Tinker's Avatar
No experience with the center dump headers.
Fentons (newer versions) on the drivers side usually need to either be milled a bit or a little grinding on the center output to get some space around stock steering box. Also have to remove them anytime you pull the engine.
Not sure about Reds availability or fit. But I have not heard anything negative about them.
Old 03-03-2018, 10:49 PM   #4
38bill
38bill's Avatar
I have Reds headers in my '38 pickup and they fit perfectly and are very well made. Dont know if they are still making them.
38bill is offline   Reply With Quote
Old 03-04-2018, 07:32 AM   #5
jimTN
This is a good thread as the question actually concerns 36-40 both cars and trucks because the frame and steering gear dimensions are the same. I too have wondered about those "center drop" headers fitting earlier Fords. Maybe someone will speak up that has actually installed a set.
jimTN is offline   Reply With Quote
Old 03-04-2018, 07:47 AM   #6
39portlander
I got looking through more books and the above mentioned exhaust manifolds may be for a 60 H.P. those are a center drop.
52-9430 same manifolds used on both sides of the engine for 38-39.
Old 03-11-2018, 12:01 PM   #7
Trekemeyer
Hi Scott would be interested in those exhaust manifolds if you could find them . You can reach me anytime at 518 573 7447 thanks Trekemeyer.
