#1 |
Who makes the best aluminum head for 24 stud engine with a .040 bore & high lift cam Int. .373 & Exh. .361. I have talked to Offenhauser & Edelbrock & both say their heads will work.
Need some suggestions if any has used them. |
#2 |
Navarro
#3 |
B-O-B,
My 8ba, 0.060 overbore, with a Kiwi-L100 cam (0.368/9 lift) is equipped with Edelbrock 1115 aluminum heads. No problems. Manufacturer's specs state clearance up to .410. Richard
twodeuces |
#4 |
Edelbrock.
#5 |
ED Pitts which # head? ,looks very nice. & Thank You
Richard Rink Thanks also sounds like that could work. |
#6 |
In contrast, about 20 years ago I had another engine built for me by a "pro". That one was a 276" with a MAX-1, a 390 Holley, MSD ignition, and Offenhauser heads. This was before the "Barn", and I don't think either I or the builder knew about "squish" and the heads were just bolted on with no checking or anything. I realize it was 20 years ago, but I distinctly remember being a little disappointed in the way that engine ran. It was OK, but it just seemed to be lacking something, and had a slight (traffic related) overheating problem I could never solve. Looking back, I'm sure that the lack of head preparation contributed to the disappointing (to me) performance, while the overheating problem was probably caused by the MSD "Ready to Run" distributor that most likely had an SBC advance curve. I sold the car that it was in (a '36 3-window ) about 5 years later because I was never really happy with it. In retrospect, had a resource like "The Ford Barn" been around back then, I would probably still have that car.![]() BTW, I have a set of new Offenhauser heads on the shelf collecting dust. Last edited by tubman; 02-24-2018 at 01:39 PM. Reason: Final thought |
#7 |
Very happy with how my 284" 59A/B runs with Offy 425 heads (.425 valve clearance), but have also been plagued with overheating in traffic in spite of doing everything short of an electric fan. I know it is contrary to the concept of aluminum heads, but I wonder if there is something about the Offy heads that makes them prone to overheating?
#8 | |
#9 |
[QUOTE=B-O-B;1597294]ED Pitts which # head? ,looks very nice. & Thank You
Those are 1126's |
#10 | |
c
These Offy heads have been around for 50 years so seems very unlikely that such a problem would have gone un-diagnosed. But then, we just discovered that anti-bacterial hand soap increases susceptibility to infection. Anybody out there with Offy heads that does NOT have cooling problems at idle? |
#11 |
I have Offy 400 heads on a 276 in my avatar and have had no problems. The heads CCed at 60-62 CCs. Distributor is a Mallory dual point set at 18 deg's total and all in between 2,000-2,500 RPM.
#12 |
Just like the intake manifold question, there have been a number or dyno test run on various heads. Why not check out the dyno articles.
#13 | |
A properly built and installed flathead will not overheat at idle or anywhere else in the operating range of the engine. Almost all heating problems are caused by the engine builder neglecting to perform the first and most important step in the rebuild. That is, acid strip the block. Stripping should be done BEFORE magnafluxing and pressure testing. |
#14 |
Sharp Heads are the best for us
#15 |
Allot of good information here, in some places acid stripping isn't available, but bake cleaning is very good. As for the heads, the quench is very important especially for a street engine.050" max I shoot for .040.. Another probable with heads is the CR. THe only way to check that is by CCing them.
Good luck |
#16 |
Ron - I don't "cc" my heads anymore. The last two sets I worked on to bring them to a consistent .050 "squish". After I installed them and ran the engine for a while, I checked the compression, and it was 160 on all eight cylinders. I don't know what compression ratio that comes out to be, but the engine starts easily and runs great.
When you think about it, shouldn't the exercise of getting the proper quench automatically bring everything else (compression ratio, chamber volume) into line? It appears it has for me. (One thing I do know is that my '67 L79 SBC is factory spec'd at 160 lbs compression and 10.25 CR; I'll take that.) |
#17 |
Believe Ron is concerned about the CR being to high for a street flathead on pump gas. A 10.25 CR would be very high for most street flatheads. Dyno test have shown the best performance on street flatheads was in the 8 to 9 CR range.
#18 |
Ford L-head V8s have a trade off point between good breathing and compression ratio. So many of the aluminum heads have chambers that are good for compression but may not help with breathing or flow due to the chamber's shape.
The research JWL has in his book is excellent for answering many performance questions. It's hard to say whether cylinder head design or composition has anything to do with overheating. I'd figure it to be a very minor variable unless the coolant flow in the head is poor. |
#19 |
"JSeery" - You have to realize that the cam timing on the L79 is quite a bit more radical than the 8CM I am using. While the compression pressure is about the same, I would expect that the dynamic compression ratios are quite different. I think my flathead has about 7.5/8:1 with all things considered. If the SBC had the same cam timing as the flathead, I would expect the compression pressure to be much higher.
