Old 02-18-2018, 12:48 PM   #1
doug.nichols
doug.nichols's Avatar
Default Ammeter for 12 volt model a
Is it necessary to install a 12 volt ammeter in a model a that has been converted from a 6 volt system? Or, will the original ammeter work ok?
doug.nichols is offline   Reply With Quote
Old 02-18-2018, 12:56 PM   #2
Jemelton#
Jemelton#'s Avatar
Default Re: Ammeter for 12 volt model a
When measuring Amperes, Voltage isn't an issue (except for limiting high voltages).
Amperage is a measure of flow, while voltage is a measure of pressure.
an original ammeter will work on a 12v system as long as you keep the amps below the limits of the meter.
Jemelton# is offline   Reply With Quote
Old 02-18-2018, 12:58 PM   #3
doug.nichols
Thank you.
