02-17-2018, 05:07 PM | #1 |
Front Motor Mount 1956 Year with 302
The lower Core Support holds the Front Motor Mount. The arrangement I think supports the front end sheet metal.
With an engine swap, mine to a 302 motor, what can I do to support the sheetmetal now? The front mount is no longer attached and the front end does move a bit. |
02-17-2018, 08:39 PM | #2 |
Re: Front Motor Mount 1956 Year with 302
On a baby bird the front body sheet-metal fastens to the big U shaped radiator support. Which is held up by welded on brackets resting on rubber pads on two small brackets welded to the frame.
Might something like this work for you? . Last edited by dmsfrr; 02-18-2018 at 09:55 PM. |
02-17-2018, 08:55 PM | #3 | |
You have a 302/5.0L swap and the engine is supported how? Please describe the installation, and... Got your PM, but before we can go any further, I need to know what was done to the frame...
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
02-18-2018, 02:46 AM | #4 | |
02-18-2018, 08:34 AM | #5 |
Below is an ILL of a 56 Sedan Frame-
5019 is No. 1 Cross-Member- This member holds the front of the front clip assy up on a mount. You can shim that mount under the core support to level the front clip. _________________________________ -EDIT - ADDITIONAL INFO- This front Cross-Member is subject to corrosion damage and can be replaced as needed (still available). _________________________________ No. 2 Cross-Member is a part of the frame assy, and carries the engine supports/mounts. Is your engine swap the same or different somehow?
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... Last edited by KULTULZ; 02-19-2018 at 03:04 AM. Reason: ADD INFO- |
02-19-2018, 03:03 AM | #6 | |
Wondering about your setup. Was the car purchased with the engine swap already performed?
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... Last edited by KULTULZ; 02-19-2018 at 03:12 AM. |
02-19-2018, 01:47 PM | #7 |
Got The Flag out today.
The car has been put (down) away until Th. While repairing the steering ram grommets, I looked over the front end a bit. It appears to me the fenders, inner fenders and core support hang above the frame. When driving the car, it looks like the fenders are bobbing up and down a bit. I don't remember this from my last wagon 46 years ago. K do you have a blow up concerning a Model 59C? Your illustrations are different from my car. The engine swap was done before purchasing car, looks like usual setup, mustang engine mounts? With a transmission mount setup. Do you know the process for leveling front clip? I will look over the front X member for any connection on Th and the the second X member is tubular. What is the process for leveling front clip? From what I've seen concerning previous work, I would not be surprised to find the bolt, shims or grommets missing on front X member. Last edited by Jwawhite; 02-19-2018 at 01:54 PM. |
02-19-2018, 04:12 PM | #8 | |
At No. 1 X-Member. the core support rides on as the ILL shows. Make sure the mount/hardware is intact. You shim/shim pack that mounting to raise the front clip. I need photos if possible of how the engine was installed (mounts on No. 2 - tubular) X-Member.
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... Last edited by KULTULZ; 02-21-2018 at 04:50 PM. |
02-19-2018, 06:28 PM | #9 |
Thursday photos will be taken and I'll post them.
Isn't that something, the front clip of car rests on the center point of core support to the first X member. |
02-19-2018, 07:55 PM | #10 | |
Re-read my earlier posts. That No. 1 (5019) X-Member is subject to corrosion. Replacement are available.
02-21-2018, 11:40 AM | #11 |
What is this? Aftermarket? This brace may be supporting the front end sheet metal. I won't be able to mount this bracket on mine for there is an aftermarket tubular finned auto transmission cooler there. dmsffr mount system looks doable on mine (your work looks great btw dmsffr. Thinking of L brackets off frame side supports with-body mount pads- welded to core support...preliminary thoughts. I've ordered the 49-59 Illustrative Manual on CD and perhaps the above mount is in it.
02-21-2018, 12:32 PM | #12 |
That is factory. Sets the height of the splash pan and front end sheet metal. Check the Hot Rod Reverends post on this site. Last page, close to bottom shows that bracket and what happens if it isn't there. His site has lots of very good info. He also sells a cd with service manuals on it. Check that out if you don't have them.
Ben |
02-21-2018, 02:47 PM | #13 | ||
If you look closely under the 16138 is an insulator. This supports the complete front end assy. There is a rubber insulator there (AD 8125-B). This has to be sound and where you would adjust the front assy for height/level if necessary. The MPC PARTS ILL shown (Re: Typical) is showing the 57/57 support system. This may cause confusion. Are you saying this bracket is missing on your wagon?
02-21-2018, 04:21 PM | #14 |
Yes, it's missing, apparently removed for Trans cooler, will have photos Friday. Explains front end bobbing....more corners than I can count were cut on this car.
I'm afraid to do a compression test..... Last edited by Jwawhite; 02-21-2018 at 07:08 PM. |
02-21-2018, 04:43 PM | #15 | |
It would be difficult to say all it has been through. Your 302, is it carbed or injected? Trans type?
02-21-2018, 11:36 PM | #16 |
It's a 1994 302 fuel injected, AOD with tv cable. OBD1 with readable port.
02-22-2018, 01:06 PM | #17 |
02-24-2018, 07:19 PM | #18 |
dmsfrr, yes, I was thinking about attaching the Trans Cooler to the underside of the Stone shield in front of the lower bracket (possibly) behind the front bumper. It appears the mechanic welded two tabs to the Radiator bracket and frame--- then proceeded to make a frame pad sandwich. Question is since the front sheet metal is somewhat attached to the frame, why the perceptible movement of fenders? Thank you K for the frame diagram, above, note the lower front bracket welded to the frame with an eyelet fore and aft. Was the rear eyelet the original connection of bracket that surrounds radiator? I see no other tabs on that piece to hold the core support assy.
02-24-2018, 07:41 PM | #19 |
I'm not familiar enough with the front sheet-metal layout to have an idea.
02-24-2018, 07:51 PM | #20 | |
Whoever did this conversion was not detailed orientated. From what I can see the original frame brkt was cut out and the center brace(s) have no support. Here is the bottom brkt which has been left out- https://www.ebay.com/itm/1955-1956-F...O/222748371144 Keep it under 120MPH!
