Old 02-16-2018, 03:00 PM   #1
einstein
Default 460 grounding
I have a 460 and using a Power Master starter. Is it beneficial to use a grounding strap from the starter to the frame?
einstein is offline   Reply With Quote
Old 02-16-2018, 03:19 PM   #2
Brian
Brian's Avatar
Default Re: 460 grounding
You can never run too many ground cables
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 02-16-2018, 03:27 PM   #3
JSeery
JSeery's Avatar
Not sure what the specific engine has to do with it, but yes. Starter to frame, engine to frame, body to frame, on and on. On most modern cars you will see dedicated grounds for just about everything.
Old 02-16-2018, 07:57 PM   #4
AnthonyG
AnthonyG's Avatar
Always a good idea to ground to chassis. Probably doesn't need to be said but keep ground terminations clean with a bit of electric conductive grease to stop metal to metal corrosion at the termination.
Nomad
AnthonyG is offline   Reply With Quote
