#1 |
Hello, I did some searching but couldn’t find the answer I was looking for. I currently have the center link out of my car to tighten up some slop from a worn out idler arm and drag link. I disassembled the drag link and layed out old parts on bench in order but unfortunately they got moved around on me. I’m trying to figure order the spring and plug go. Does it go Plug first then spring over it our spring in first then plug 2nd?
#2 |
not Sure if these help explain what I’m asking
#3 |
I found my answer I believe, plug goes in flat side first then spring slides over it.
#4 |
https://www.ford-trucks.com/forums/1...k-diagram.html |
