Old 01-15-2018, 11:50 PM   #1
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Remund electronic ignition
Does anyone have the wiring diagram or instructions for one of these?
Old 01-16-2018, 06:06 AM   #2
Dollar Bill
Dollar Bill's Avatar
Default Re: Remund electronic ignition
Does it look like this?
Remund electronic ignitions was absorbed by First Street Ignitions. When I talked to their tech staff, they advised wiring is the same for their current distributors. But please call to confirm - Phone 580-762-8322.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 01-16-2018, 06:39 AM   #3
42merc
42merc's Avatar
save
42merc is offline   Reply With Quote
Old 01-16-2018, 09:53 AM   #4
steve s
steve s's Avatar
Is this what's called the Transistor-Reluctor system with the box that mounts on the firewall? If so, I've got the instructions, as well as an unused kit I'll sell cheap.
steve s is offline   Reply With Quote
Old 01-16-2018, 10:41 AM   #5
denis4x4
denis4x4's Avatar
Check here:
http://www.fsignitions.com/FS_Ignitions_Home_Page.html
As others have said, FSI purchased Remund and should be able to help you out
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 01-16-2018, 08:59 PM   #6
Chuck Sea/Tac
Guess I’ll have to call them . This is just the simple 6V pos grd electronic ignition. I think it’s just a halls effect. This was purchased in 97. Been running strong ever since.
Old 01-17-2018, 05:20 AM   #7
Benson
Originally Posted by steve s View Post
Is this what's called the Transistor-Reluctor system with the box that mounts on "the firewall"? If so, I've got the instructions, as well as an unused kit I'll sell cheap.
I think the one that you have MIGHT be similar to this design.
When i worked at the VW Dealer in mid-60's some customers installed an ignition system with box on the "firewall". I think it was called CDI Capacitive Discharge Ignition. There was a red push button on side of box to change from CDI to standard system. The box had an anodized gold color heat sink on outside of case if I remember correctly.
It was a very early design which did NOT USE a magnetic pickup like the FSI system. Instead it still used the points to trigger the CDI circuit.
The idea was that the transistor circuit would lower the current through the points when the points opened, thus greatly reducing arcing and increasing point life.
My '69 and '73 VW type IIIs with stock ignition used standard points which were replaced every 3000 miles when oil change and valve adjustment was done. I never adjusted points once installed unlike with points installed in Model As today which require adjustment after a couple of hundred miles.
Someone must know how to to make a point rubbing block that lasts 3000 miles today.
Benson is offline   Reply With Quote
Old 01-17-2018, 10:26 AM   #8
katy
katy's Avatar
I made this one out of some hard fibre I had, but it'll take some time before it gets to 3000 miles.
Old 01-17-2018, 10:33 AM   #9
steve s
steve s's Avatar
Here's whereof I speak.
Old 01-17-2018, 08:34 PM   #10
glenn in camino
glenn in camino's Avatar
I gave up on my electronic ignition and went back to the stock points. Now my Model A runs better than ever. It's all Henry.
glenn in camino is offline   Reply With Quote
