#1 |
Hello Ford Enthusiasts,
when i turn the steering right, the drag link grinds on the tie rod. And when i turn left, the tire-wall grinds on the drag link.... Now i started to take everything off, to find the cause. The pitman Arm looks a little bit bent, or is that the right shape? Any more Ideas to find a solution? Thanks a lot, Nico |
#2 |
Thats a common problem on a model A.
maybe if you do a search on the A forum you will come up with an answer. Lawrie |
#3 |
Thank´s Lawrie,
i found many posts about that Problem, so i take off the spring in front. Centerbolt was broken into four pieces... Does anybody know, how many layers the front-spring should have originally on the ford BB-Truck? Thanks, Nico |
#4 |
Could anybody provide me with the drawings of the BB Truck front axle?
Greetings out of the workshop, Nico |
#5 |
If you look in the parts book,(green bible) it should have the spring info,
If you cant find it let me know and I will see if I can find it in my books. Lawrie |
#6 |
with 157 inch w/base 14 leaves. If you want a parts list of the spring and leafs let me know and I will copy the page. Lawrie |
