Old 01-02-2018, 06:46 PM   #1
1930-Pickup
Default Les Andrews: Trimming of Motor Mount Rubber
In the Les Andrews book he speaks of trimming the new rubber pads for the stock rear motor mounts. Its basically remove the three protrusions for the frame holes, and remove the entire lower flap. This trimming is apparently required to facilitate installation of the pads since they don't fit the frame properly.
Is this procedure still valid and required? I thought since the publication of the book the parts would have improved and this procedure would no longer be required?
The pads that I have came from Bert's and are listed as USA. Do these pads need the trimming?
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 01-02-2018, 07:22 PM   #2
Nathan_1929
Nathan_1929's Avatar
Default Re: Les Andrews: Trimming of Motor Mount Rubber
I did not have to do any trimming on the rubbers from Mikes that I just installed. It was a snug fit, but felt good to me.
Nathan - 1929 Closed Cab Pickup, 1929 Tudor, 1930 Coupe, 1941 Pickup - Vintage BMW Motorcycle Collector/Mechanic
Nathan_1929 is offline   Reply With Quote
Old 01-02-2018, 07:26 PM   #3
700rpm
700rpm's Avatar
I trimmed mine, and it was still a tight fit -- 1/16" on each side.
Ray Horton, Portland, OR
Old 01-02-2018, 09:08 PM   #4
2manycars
2manycars's Avatar
That may depend on where you buy the rubbers. Some are correct, some are much too thick. The correct ones only have the dimples on one half.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 01-02-2018, 10:47 PM   #5
Simonpie
Interesting. The new ones I got didn't have the "shelf" or L angle shape. The old ones didn't have it either and still seemed plenty fresh, so I reused them. Does the body sit on the shelf? I have a speedster, so I'm not sure how the original interacts.
Simonpie is offline   Reply With Quote
Old 01-02-2018, 11:08 PM   #6
BillCNC
BillCNC's Avatar
Which book (1,2 or 3) and what page does Less talk about modifying the mounts. I'm at this point now.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 01-03-2018, 12:09 AM   #7
SeaSlugs
SeaSlugs's Avatar
I think it was brattons who had them correctly made - several suppliers stock thier properly made ones. I used a set and fit like a glove and engine slid right in with a hair bit of grease on the mounts to flywheel housing.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-03-2018, 12:10 AM   #8
1930-Pickup
Regards
Bill
Bill-
Vol I, page 1-221.
Alex
Old 01-03-2018, 12:14 AM   #9
1930-Pickup
I hope Bert's was one of them. Their stuff is usually good, so no worries. I'll do my mounts this week...unless I keep procrastinating.
Old 01-03-2018, 12:17 AM   #10
1930-Pickup
I'm sure glad I didn't just cut them like the book said to do. It really pays to hear the voices of experience on jobs like this!
Old 01-03-2018, 04:03 AM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
My last 2 sets of rubber pads came from Snyder's and fit perfect.
Old 01-03-2018, 06:39 AM   #12
Steve Plucker
NO...It is NOT Bratton's pads...As Tom says above...It is Snyders's pads that 1) are more plyable and not so hard, 2) they are slightly thinner than Brattons that make them lots easier to work with; 3) NO trimming on these Snyders Pads.
Pluck
Old 01-03-2018, 08:02 AM   #13
Ray Young
Ray Young's Avatar
I recently installed the Snyder’s pads and had no issues either.
Ray Young is offline   Reply With Quote
Old 01-03-2018, 08:21 AM   #14
2manycars
2manycars's Avatar
The "L" angle rests on the bottom rail of the frame and the mount is on top of that to provide a support besides the bolts.
Bill
www.brauchauto.com
Old 01-03-2018, 09:59 AM   #15
JohnLaVoy
JohnLaVoy's Avatar
The pads have been improved so the trimming is no longer necessry.
JohnLaVoy is offline   Reply With Quote
Old 01-03-2018, 10:14 PM   #16
Tom Wesenberg
Here is a link to some information on Vince's site:
http://www.fordgarage.com/pages/aeng...rtcushions.htm
Old 01-06-2018, 05:02 PM   #17
1930marie
1930marie's Avatar
Hi Tom - I ordered with Tom at Snyders this morning- he is encyclopedic. You installed with no trimming, is there a trick to make the installation easier? I read Les's instructions, I had to read the part about pounding out the motor mounts a few times. Any tips? Thanks!
They know enough who know to learn.
1930marie is offline   Reply With Quote
Old 01-06-2018, 08:27 PM   #18
Tom Wesenberg
No problems at all, just lay the rubber pads on each side of the frame, then slip the steel sleeves in the centers of the rubber holes, then the motor mounts and bolts. The sleeves won't allow the rubber to be squeezed too tight.
Old 01-06-2018, 08:49 PM   #19
1930-Pickup
I'm at this point now, but there is no way I have enough gap to install the parts like this. Frightening words like 'bent frame' run though my head, but there is no damage anywhere. There is some frame sag, but I don't think it would cause this problem...would it?
Old 01-06-2018, 10:29 PM   #20
1930marie
1930marie's Avatar
Thanks Tom.
