Old 01-01-2018, 07:28 PM   #1
Fred K-OR
Fred K-OR's Avatar
Default Carb Help needed please!
As some of you may know, I am the one that knows little about the finer workings of the old Model A. So I always have lots of questions.
Being bored in these winter months, I decided to try my hand and rebuilding an extra carb. Well I got all the main pieces I needed, upper and lower bodies and ordered new parts from one of the vendors and got everything put together. Put it in the old coupe, was surprised it started, but the old rig just did not run well at all.
The problems: 1) it is running to rich. Ruff running with black smoke out the tail pipe. Turn the GAV all the way in but does not make any difference. But I did find that I needed to put in the little fitting in the GAV hole. Put this fitting in, started it with the GAV all the way in and still the same problem
2) second problem is that when I take it out for a drive, when I press on the gas, the carb backfires and it almost quits. This does not make sense based on problem #1 above.
So what am I doing wrong? Do I have something plugged up somewhere? If so where" Do the upper and lower bodies I pickup up have a problem in them somewhere? I did use all new parts for all the things that can be changed in the carb. I was thinking that I should swap out the upper and lower bodies with a known good one. This may be my next step. Bought the new parts from one of the best suppliers in the industry. Please help this old bored guy.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 01-01-2018, 07:42 PM   #2
160B
160B's Avatar
Default Re: Carb Help needed please!
Start here at Model-A.Org website. Everything you need at one website, but there is a lot to digest.
http://model-a.org/
here is a table for trouble shooting
http://model-a.org/troubleshooting.pdf
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 01-01-2018, 07:43 PM   #3
jm29henry
jm29henry's Avatar
Great to ask questions,!!! We all need to learn.Did you set the float.? What are your jet sizes? Are all passages clean? Do you have the jet in side the GAV ?do you have any books for specs?
jm29henry is offline   Reply With Quote
Old 01-01-2018, 07:45 PM   #4
30aadoodlebug
30aadoodlebug's Avatar
Hows the float level? I had a similar problem with a zenith i rebuilt, and the float was set too high.
30aadoodlebug is offline   Reply With Quote
Old 01-01-2018, 07:48 PM   #5
AL in NY
AL in NY's Avatar
I don't know how thorough you where in rebuilding the carburetor, but all brass plugs should be removed and the passageway cleaned, especially under the GAV needle. In most vendor carburetor kits, the jets are not the correct size. Before using they should be flow tested. Fuel float should be checked for leaks and set to the correct height.
AL in NY
AL in NY is offline   Reply With Quote
Old 01-01-2018, 08:00 PM   #6
160B
160B's Avatar
Also at Model-A.Org website.
To aid in troubleshooting, common symptoms are noted and their most common causes are identified.
http://model-a.org/symptoms.html
Old 01-01-2018, 08:06 PM   #7
Fred K-OR
Fred K-OR's Avatar
I did set or checked the float.
The jets were all new purchased from Brattons. So I assumed they were the correct sizes.(maybe this assumption is my problem). I tried to blow all passages out with air. I did put the jet inside the GAV.
So tried to do the things that I heard were the things to do. But somewhere I have not found the problem(s).
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 01-01-2018, 08:10 PM   #8
Fred K-OR
Fred K-OR's Avatar
I have not removed the brass plugs which in this case, maybe I should do being I purchased the upper and lower bodies and do not know what shape they are in. I did check and set the float valve for adjustment and float for leaks. But looks like I need to get into it more!
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 01-01-2018, 08:26 PM   #9
Fred K-OR
Fred K-OR's Avatar
Good stuff 160B. I forgot about Bert's web site which has much info that I need to study.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 01-01-2018, 09:15 PM   #10
Gary WA
Gary WA's Avatar
Jet Sizing-all old washers removed from jets including gav.No washer on idle jet!
www.whidbeymodelaclub.com
Old 01-01-2018, 10:13 PM   #11
160B
160B's Avatar
New jets are not correctly sized and to be successful in the rebuild jets must be flow tested and appropriately resized to provide correct flow. Also if passages are not verified clear you will not be successful in your rebuild.
Old 01-01-2018, 10:14 PM   #12
Fred K-OR
Fred K-OR's Avatar
Gary, looks like you have done a few carbs. I am still learning and have a lot to learn.
I think the first thing I need to do is make sure all the crud is out of the lower part of the carb. I saw a lot of rust in this part and thus I am thinking that some of the passages are plugged up.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 01-01-2018, 11:51 PM   #13
midgetracer
midgetracer's Avatar
Renners Corner sells the flow tested jets. They also have all necessary parts at a reasonable price. I would not drill out the brass plugs. Many carbs have been ruined doing that. I use a fine stainless wire to run through the passages and usually get all the rust and crud out. Good luck
midgetracer is offline   Reply With Quote
Old 01-02-2018, 06:25 AM   #14
RonC
RonC's Avatar
I wouldn't drill out and replace plugs. You run the risk of cracking the casting when forcing in new plugs. Not necessary. Glass bead the passages and run paper clips through the passages to check
RonC is offline   Reply With Quote
Old 01-02-2018, 07:30 AM   #15
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
I hope you did not leave out the venturi!!!!!! It has been done.
Jacksonlll is offline   Reply With Quote
Old 01-02-2018, 07:56 AM   #16
zzlegend
zzlegend's Avatar
Fred, if that bottom piece was very rusty, you might want to soak it for a day or two in some evapo-rust. It works great for removing rust. As stated earlier, get a piece of fine wire and run it thru all the orifices. That's what I always do when I rebuild them. I would not do any drilling on any of it unless absolutely necessary. Patience, patience. You will get it. Just my 2 1/2 cents. Good luck with it.
zzlegend is offline   Reply With Quote
Old 01-02-2018, 08:12 AM   #17
Terry, NJ
Terry, NJ's Avatar
The problem is that a little too much gas is getting through as opposed to too little. Go through all of the fuel regulation parts of the carburetor, Float, float valve, jet sizes ETC. There are no mysteries in mechanics, only questions whose answers are not immediately obvious!
Terry
Terry, NJ is offline   Reply With Quote
Old 01-02-2018, 09:30 AM   #18
Big hammer
Hidden passage's need to be open, I believe Tom Eddy has talked written about this! Using a paper clip and bending to get through the passages. Following the step by step and you will successful in your rebuild :-)
get a bigger hammer tap done
Old 01-02-2018, 10:38 AM   #19
Fred K-OR
Fred K-OR's Avatar
Don't laugh you all! I did do that on another carb
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 01-02-2018, 10:40 AM   #20
Fred K-OR
Fred K-OR's Avatar
Thanks guys. You gave me a lot to work on the. Great challenge to work on in the cold garage.
Fred Kroon
1929 Std Coupe
1929 Huckster
