Old 01-01-2018, 02:00 PM   #1
1949mercury
1949mercury's Avatar
Default First time for Coolant ?
First time putting coolant in my Flathead & heater core. Just got it hooked up yesterday. Should I just run water and flush it out or put a 50/50 green coolant mix and see how it goes? Thanks for the help.
File Type: jpg 5C537FC5-D470-4605-8EE5-B72F63884A8D.jpg (72.9 KB, 115 views)
File Type: jpg A71B2A43-53C0-4A4C-A6B9-938A4C707D9D.jpg (52.3 KB, 117 views)
1949mercury is offline   Reply With Quote
Old 01-01-2018, 02:08 PM   #2
J Franklin
J Franklin's Avatar
Default Re: First time for Coolant ?
I would run water until you are satisfied there will be no leaks or seepage inside or out.
J Franklin is online now   Reply With Quote
Old 01-02-2018, 09:27 PM   #3
1949mercury
Ok thanks. That seems like a good idea.
Old 01-03-2018, 12:24 AM   #4
slowforty
slowforty's Avatar
Mr Franklin is correct Water is a lot easier to clean up.
slowforty is offline   Reply With Quote
Old 01-03-2018, 12:25 AM   #5
Drbrown
Drbrown's Avatar
I agree but recommend (1) don't run plain water too long before getting some anti-corrosive protection and water pump lubricant in there, and (2) whatever antifreeze/anti-corrosive you finally put in, mix it using distilled water rather than tap water .... available at the supermarket; it's not expensive. Some may use premixed coolant but I don't think its worth the higher cost not to mix your own.
Also, if you have i.e. an aluminum radiator, it needs a special coolant.
Drbrown is offline   Reply With Quote
Old 01-03-2018, 02:41 AM   #6
1949mercury
Thank you. All stock radiator and motor. I have heard about the distilled water sounds like a good idea. Was thinking about buying the premixed will have to think about that one.
Old 01-03-2018, 08:40 AM   #7
corvette8n
corvette8n's Avatar
I like to mix my own so it reads -50 on my antifreeze tester, our weather here is cold, have had -35 to -40 in the past.
Old 01-09-2018, 02:37 AM   #8
1949mercury
I got 3gl of green concentrate antifreeze & 3gl of distilled water and a bottle of water wetter will see if I have any leaks & look for gauges later.
Old 01-09-2018, 08:34 AM   #9
19Fordy
19Fordy's Avatar
buy an infarometer and use it to check temp since you don't have gauges.
Old 01-09-2018, 08:39 AM   #10
19Fordy
19Fordy's Avatar
Buy a digital temp gun even if you did have gauges.
You can check the temp of water at top and bottom of radiator.
https://www.walmart.com/ip/Non-Conta...&wl13=&veh=sem
Old 01-09-2018, 09:08 AM   #11
34PKUP
34PKUP's Avatar
ttps://www.ebay.com/itm/Digital-Infrared-Temperature-Temp-Gun-Thermometer-Non-Contact-IR-Laser-Point-USA/112556229268?_trkparms=aid%3D555019%26algo%3DPL.BA NDIT%26ao%3D1%26asc%3D20150817211623%26meid%3D88d7 ce8433284ab8ad408f197107f5e1%26pid%3D100505%26rk%3 D1%26rkt%3D1%26&_trksid=p2045573.c100505.m3226
Suggest you check to see if any links you post actually work before posting.
And what's with the nonsensical bold type??
34PKUP is offline   Reply With Quote
Old 01-09-2018, 10:30 AM   #12
B-O-B
B-O-B's Avatar
Harbor freight has a digital heat gun for reasonable price. Every body should have one.
B-O-B is offline   Reply With Quote
Old 01-09-2018, 07:02 PM   #13
19Fordy
19Fordy's Avatar
Didn't mean to upset you. I find that the bolder type makes it easier to read.
Here's the new and improved temperature tool posting.
PS: When I was a youngster I used to let insignificant things annoy me.
As I matured, I learned not to sweat the small stuff.
Old 01-09-2018, 08:28 PM   #14
51 MERC-CT
51 MERC-CT's Avatar
Sounds like something that comes with old age.
A transition from being the 'annoyed' to being the 'annoyer'
Old 01-09-2018, 08:55 PM   #15
Drbrown
Drbrown's Avatar
I'm about 80 and too stiff to put my foot in my mouth. I find I should say what I intend to say two times to myself, sleep on it, then finally say it out loud. Just need to convince the Lady of the house to do the same.
Old 01-10-2018, 12:49 AM   #16
1949mercury
Thanks for the info. I will look at harbor freight I like there 20% off. Also have a buddy looking to see if he has any gauges laying around he doesn’t want. Took 4 gallons already and haven’t even started it up. Can you run mechanical temp gauges and the stock electric gauge ? I don’t think you can just wondering.
Old 01-10-2018, 04:31 AM   #17
51 MERC-CT
51 MERC-CT's Avatar
Yes, you can run both stock and mechanical gauges.
The problem is, just how innovative you can be finding or creating a place to mount the sending units.
For example, I am running metal upper hoses (like pickup trucks) and the sending units are mounted in them.
Old 01-11-2018, 02:45 AM   #18
1949mercury
That’s nice. I saw some pictures of the thermostats in the water necks.
I also got a 4lb radiator cap tonight. The guy also gave me some Mercury Door sill plates ��
Old 01-11-2018, 06:20 AM   #19
Tim Ayers
That's funny.
Old 01-27-2018, 04:53 PM   #20
1949mercury
I got a infarometer from Harbor freight temp was around 200. I have a crack in my thermostat housing need to get a new one. Now I was wondering what is the best one to get. Stock, chrome saw some with studs instead of bolts. Also my thermostat looks pretty outdated.
File Type: jpg 3AA3E672-3A10-4EF5-BF5C-F50E4FA01F09.jpg (58.3 KB, 27 views)
