Old 12-24-2017, 07:46 PM   #1
Nathan_1929
Nathan_1929's Avatar
Default 1928 transmission case lacking holes for throw out carrier
I've built up the best of a few transmissions and I'm re-assembling one on the bench right now.
Turns out, my best candidate is an early transmission case that lacks the 4 mounting holes for the throw out bearing carrier/snout.
I haven't found how the carrier is attached on a 1928, but I'm considering drilling/tapping the case to accept the 4 bolts for the snout that I have.
Is the early case valuable/desirable without these holes? I don't want to ruin something rare that could be of use to a meticulous restorer.
Nathan - 1929 Closed Cab Pickup, 1929 Tudor, 1930 Coupe, 1941 Pickup - Vintage BMW Motorcycle Collector/Mechanic
Nathan_1929 is offline   Reply With Quote
Old 12-24-2017, 08:07 PM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: 1928 transmission case lacking holes for throw out carrier
Multi Disc Clutch Trans Case???
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 12-24-2017, 08:26 PM   #3
GRutter
GRutter's Avatar
That would also be my guess. MultiDisk clutch used a different setup, including bell housing, trans shaft, throwout bearing etc. But I believe the only difference in the transmission housing is that there were no holes tapped that would be needed for the snout.
GRutter is offline   Reply With Quote
Old 12-24-2017, 08:47 PM   #4
J Wade
My multi disc is the same way throw out bearing is mounted to the clutch pack. Personally I wouldn't drill it. It's only original once
J Wade is offline   Reply With Quote
Old 12-24-2017, 10:26 PM   #5
Ron in Quincy
Ron in Quincy's Avatar
There is also a difference in the reverse idle, the head is much larger where it goes in the case and there is a different way the oil is taken to the reverse idle gear on the inside. This feature is unique from the outside, something a Judge would look for if the "A" is in fine point judging.
Just my opinion,
Ron
I suggest you use a later case to build your transmission, just my opinion
Ron in Quincy is offline   Reply With Quote
Old 12-25-2017, 12:28 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
I agree with 4 and 5.
Old 12-26-2017, 10:12 AM   #7
JohnLaVoy
JohnLaVoy's Avatar
Finding a later trans case is easy they are all over the place save the early one for someone working on a 28, please!
JohnLaVoy is offline   Reply With Quote
Old 12-26-2017, 11:21 AM   #8
F.M.
Ford did make two different kinds of cases for the Multi disc clutch unit.. One with the Large collar in the rear, and one with out..
F.M. is offline   Reply With Quote
Old 12-26-2017, 04:40 PM   #9
Dennis Pereira
Dennis Pereira's Avatar
My files are in a mess but here's one photo with early 28 on the left
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 12-26-2017, 05:27 PM   #10
F.M.
Yes, And the 2nd type is the one on the far right.. Notice both of them have NO front holes drilled for the front bolt on piece as the middle one does..
Old 12-26-2017, 05:50 PM   #11
J Franklin
J Franklin's Avatar
The center case is also early case as evidenced by the cast bearing retainer instead of the snap ring as on the right. I think the one on the right is the latest case pictured.
Old 12-26-2017, 06:15 PM   #12
Dennis Pereira
Couple more photos same transmissions.
Dennis in Kelsey ca
Old 12-26-2017, 10:21 PM   #13
F.M.
I give up !! The shaft on the right is the Early one, The middle one is the 2nd type & the last used the rest of the time.. I think one of the trans boxes has already been drilled for later use.. So you show, One original Early type, big collar, one drilled with big flat bolt hold down plate, and the later style..
Old 12-27-2017, 03:39 AM   #14
Tom Wesenberg
#12 shows the cases earliest on the right, then next is the middle, then last is the left. Only the far right is the early one without the threaded holes for the collar.
The reverse idler shafts are shown earliest on the left, then middle is next, and latest is far right.
Old 12-27-2017, 05:35 AM   #15
Tony Hillyard
Tony Hillyard's Avatar
With the exception of the very early transmission with the larger hole in the back, do the transmission rebuild kits currently available fit all the transmissions?
Tony Hillyard is offline   Reply With Quote
Old 12-27-2017, 09:05 AM   #16
wrndln
Dennis,
Nice pictures showing the three main style transmission cases (in order). There are a couple more different style cases, but the differences are very subtle in nature from the ones shown in you pictures.
Thanks,
Rusty Nelson
Old 12-27-2017, 12:06 PM   #17
Charles Reese
Charles Reese's Avatar
Info from Judging Standards & 'other' (probably Doc K). Don't remember where i got the pix or would give them credit!
(A7006) TRANSMISSION CASE (Type 1)
{J.S.’16-E28}: large hole for transmission reverse idler shaft with a wide collar
{J.S.’11}:
● (BOP-m’28): distinguished by a reverse idler gear shaft with a 1-3/8” diameter wide collar visible at left rear of transmission case
● (BOP-Nov’29): 1/4” x 1-7/8”counter shaft & reverse idler shaft retainer at rear of case
● Ford Engine Green
{Non-J.S.} (BOP-m’28):
 Front face: no holes for main drive gear bearing retainer (A-7050) since this case was for the multidisc clutch. The bearing retainers both front and rear were part of the casting.
 Inside: smooth bosses for cluster gear … countershaft gear thrust washer (A-7119) used at each end
Charles Reese is offline   Reply With Quote
Old 12-28-2017, 11:20 AM   #18
Charles Reese
coupla FB'ers reminded me of an excellent technical site by Vince Falter ...
http://www.fordgarage.com/pages/atransmissioncases.htm
