12-22-2017, 12:56 PM | #1 |
Heater Restoration
I would like to take this heater apart, clean up the rust and paint. If I drill the rivets out what would I need to replace them? Is there a process, special tool, use substitute method to put it back together? Thank you for you assistance.
12-22-2017, 01:04 PM | #2 |
Re: Heater Restoration
One option would be to use POP Rivets. They come in various sizes,lengths, and material. I realize they are not period correct but are a means to the end. But after looking at the PICs it appears that you would be able to get to them from the back side so they could be hand set. Or maybe you could find a river squeezer to borrow or maybe ever go to a brake shop and get them to set the rivets for you.
12-22-2017, 01:09 PM | #3 |
check with restoration specialties to see if a replacement rivet is available don't know if chrome is an option if not maybe a headless screw/nut I used something like this when I was building my 28 roadster cab they will send you in the right direction
12-22-2017, 01:34 PM | #4 |
If the rust is only on the inside, I wouldn't disassemble the unit. Rather, use a rust converter and your choice of top coat. Trying to reassemble a piece like that is tough, especially if you're persnickety like me.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it Last edited by FortyNiner; 12-23-2017 at 09:44 AM. |
12-22-2017, 02:09 PM | #5 |
Maybe use SS carriage bolts to assemble. Polish the heads and they will look like chrome.
12-22-2017, 03:00 PM | #6 |
12-22-2017, 03:48 PM | #7 |
It doesn't look bad enough to go to the extreme of disassembly. You should be able to clean it up satisfactorily and paint while keeping it intact. Why chance destroying it....
12-22-2017, 05:38 PM | #8 |
dump it in a vat of citric acid, will take the rust off and not harm the SS
12-22-2017, 08:25 PM | #9 |
As Frank suggests, I would use the domed head screws that you get in headlight repair kits. Once tightened they look like rivets. Bratton's Model A, 800-255-1929, has them, PN18280 for $3.95 for a set of 12.
12-23-2017, 04:27 AM | #10 |
I just restored my heater.I used white vinegar to get the rust off ....it was similar kind of rust as it appears in your pictures......
If you do go ahead and drill the rivets out, I agree that small stainless steel coach bolts,polished up,would be your best bet. Nice looking heater btw. |
12-23-2017, 07:24 AM | #11 |
I,ve done about 20 art-deco style heaters . What you have there is minimal ageing. Don,t take the heater all the way apart for that little bit of blemish on the inside. The vinegar bath is a good idea. Brush it clean the next day.
12-23-2017, 08:42 PM | #12 |
Thank you to all for you're suggestions, greatly appreciated.
